need some help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-14-2013, 01:44 AM Thread Starter
need some help.
I've got an early 99 7.3 .
And it needs a new turbo.. I'm not sure what I should do. As putting a new early 99 turbo on or a late 99 conversion kit. Which way is worth it
129rich is offline
post #2 of 8 (permalink) Old 02-14-2013, 04:11 AM
the stryker god
Re: need some help.
If you want to go away from the stock setup a t4 is the only way to go
bruce51d is offline
post #3 of 8 (permalink) Old 02-14-2013, 04:37 AM
lincolnlocker's Avatar
Re: need some help.
depends on what your going to do with it? a beans d66 is a great turbo and is capable of close to 500hp. its also a drop in turbo.
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100s,bdp live tunes,4''down 5''back,dieselsite adrenaline,diy RR w/walbro,bellowed uppies, BTS trans!
01, rclb, 4x4, zf6, caned ts tunes, xl work truck package, 4'' tbe
lincolnlocker is offline
post #4 of 8 (permalink) Old 02-14-2013, 04:26 PM
mandkole's Avatar
Re: need some help.
x2-- you really need to answer the other mod questions first. If you cant, just rebuild the stocker. The D66 would be a good choice but could be laggy with stock injectors.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #5 of 8 (permalink) Old 02-16-2013, 12:48 AM Thread Starter
Re: need some help.
I mainly pull car/race car to the track/ horses/ and hay lol.
I'm not looking to make huge amounts of power. Just a good running truck..
It was strong just has a boost leak..
129rich is offline
post #6 of 8 (permalink) Old 02-17-2013, 03:07 AM
Catfish Mafia
li'l tugger's Avatar
Send a message via Yahoo to li'l tugger
Re: need some help.
if you were happy with the power from the stocker, keep it stock. if you want a lil more, the D66 is the only drop in that i kow of for our E99s. i went T4 so i would have options, but i dont pull trailers all that much and was lookin for power. going to newer model stock turbo would be a waste imo. lots of work for little gain.
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP,
13.94 @ 96.9mph.. on stock turbo
li'l tugger is offline
post #7 of 8 (permalink) Old 02-23-2013, 01:11 AM Thread Starter
Re: need some help.
So I was recently informed that 7.3 kinda had an issue with bolts backing out on the Turbo. I have discovered that I was missing at least the top to bolt..
My question is should I still replace the turbo or just pull and replace all bolts and possibly rebuild while its out
129rich is offline
post #8 of 8 (permalink) Old 02-23-2013, 06:01 AM
Re: need some help.
whatever budget allows man...
