reverse fpr shim mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 09-23-2008, 12:29 AM Thread Starter
With the combo in sig and stock fuel system, pump, bowl, and all, my fuel pressure was 60 at idle and would drop to 20 at wot!
I replaced the pump with a walbro 392 and fp at idle is now 75-80. I am out of zip ties, so I could not attach the gauge to my wiper to see any pressure drop. I will see what it does tomorrow.
Anyways, I want (need?) to bring the fp down. How do I do this? If you shim the spring for more, do you cut the spring for less?
Oh, and I am running the stock fuel system because I have a vegistroke system waiting to be installed.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #2 of 29 (permalink) Old 09-23-2008, 12:40 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: reverse fpr shim mod
I dont know that much about '' vegistroke"? but i do know that the INTERNATIONAL psi was sabostabe at 70 P.S.I until FORD reduced it down with thier fuel regulator CRAP!
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #3 of 29 (permalink) Old 09-23-2008, 12:45 AM Thread Starter
www.dinofuelalternatives.com
Once I get to a certain temp, I will be running off a separate fuel system.
Pretty sure a constant 60ish psi is what most people are happy with.
rpm-inc is offline
post #4 of 29 (permalink) Old 09-23-2008, 12:51 AM
owner/president
I agree with ya, but as close to 70 psi as i can get the better, but not over.Also depending on what else u-all have done to the motor.
post #5 of 29 (permalink) Old 09-23-2008, 01:37 AM Thread Starter
Mods are in sig in first post. I don't know why it doesn't show up in every post.
rpm-inc is offline
post #6 of 29 (permalink) Old 09-23-2008, 02:00 AM
Send a message via AIM to JohnT
I don't see why it would not work, just don't take off too much at one time.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #7 of 29 (permalink) Old 09-23-2008, 02:14 AM
Banned
I'd be interested to know why it's so high? Why isn't it "regulating" on it's own. It's acting more like a bleed orifice than a regulator being that changes in pump volume seem to be directly effecting the system pressure.
What's up with that? Return line kinked or something?
Charles is offline
post #8 of 29 (permalink) Old 09-23-2008, 09:13 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
cant help ya on the pump..but forget the zip locks... build your self one of these.. click on the pic to see how easy and cheap it is..the gauge came from Dennis at ITP..working a light set up now..
Ron's power stroke is offline
post #9 of 29 (permalink) Old 09-23-2008, 12:37 PM Thread Starter
I was under the assumption that the new pump would still give me 60 psi at idle like the old pump, but then be able to maintain that pressure. No kinks or anything.
But I wasn't really surprised when it wasnt.
rpm-inc is offline
post #10 of 29 (permalink) Old 09-23-2008, 12:40 PM
matthewd11's Avatar
did you ever do a FPR shim mod? Maybe something is up with the spring...
Also as far as pressure, run it around 55-57 psi at idle. Thats where i made the most power with my truck...originally at 64 psi idle and when i lowered it i gained 14 hp on the dyno...
matthewd11 is offline
