Swapped out the turbo, Now some ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 48 (permalink) Old 09-22-2008, 06:41 PM Thread Starter
BlackPearl03's Avatar
After swapping out my turbo and two injectors this past weekend. I have run into some problems. The codes that show up are P0603, P1247, and P1211. I know the P0603 is just from having a chip and pretty much nothing, same as the P1211. Now the P1247 is for turbo boost pressure low. I had that one before i changed the turbos out. What exactly does it mean and then what do i do if anything?
i also now have high egts, but im not sure if my pyro is messed up since it would jiggle everynow and again, kinda crazy like. I kinked my boost line aswell, so im not sure what the boost is, it only goes to 10. I need to change the boost line before ill be able to tell for sure.
Im also getting more black smoke. I didnt think that would happen since there should be more air with the bigger turbo.
Any help is greatly appreciated.
Thanks Drew
BlackPearl03 is offline
post #2 of 48 (permalink) Old 09-22-2008, 07:17 PM
urbanwheeler's Avatar
Re: Swapped out the turbo, Now some ?
what turbo did you have? what turbo do you have now?
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #3 of 48 (permalink) Old 09-22-2008, 07:24 PM
Busy Busy
Marty's Avatar
what he said.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 48 (permalink) Old 09-22-2008, 07:47 PM
racehauler's Avatar
And what kind of boost pressures are you seeing on your gauge?
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 48 (permalink) Old 09-22-2008, 07:50 PM
he said he only sees 10 but the line is kinked to the gauge, i would probably start with looking for up pipe leaks.
[SIGPIC][/SIGPIC]
post #6 of 48 (permalink) Old 09-22-2008, 07:54 PM
Busy Busy
Marty's Avatar
Yup uppipes, boost leaks, kinked boost tube, hell even that big O ring on the front of the turbo is good for 2 psi or so.
You could get more smoke if you went with a bigger turbo down low since it won't spool quit as fast.
Elkton, Maryland
Marty is offline
post #7 of 48 (permalink) Old 09-22-2008, 09:02 PM
kinda what i thought also, maybe your turbo is too big for the sticks youre running? what injectors do you have?
[SIGPIC][/SIGPIC]
post #8 of 48 (permalink) Old 09-22-2008, 10:16 PM
Back to Civilian Life!!
MILFORD's Avatar
EBV stuck closed? I know that happened to me and my EGTs were through the roof and my boost was only pushing 10 maybe.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #9 of 48 (permalink) Old 09-22-2008, 10:24 PM Thread Starter
went from a stock turbo to a tn bb. Its used and one of the good ones. i have stock sticks. i got the kink in my boost line fixed and it still doesnt make more than 10 psi and egts still high. I replaced the turbo and pedistal orings. gutted the ebpv. After gutting the ebpv, could i cut the wings off the butterfly valve??
This was my first turbo install/removal. I had a lot of trouble with getting the y collector connected to the turbo. I got it finally and the rear bolt to mount the turbo to the pedistal was lined up, but the front one was off about an eighth of an inch. So i took a pry bar and tweaked it over and got it in. Could that have caused the uppipes to leak?? or something like that?
Any help will be nice for when i tear it back apart this coming weekend
post #10 of 48 (permalink) Old 09-22-2008, 10:30 PM Thread Starter
i gutted the ebpv this weekend. I wonder if i wired the butterfly valve the wrong way. I dont think i did, but how could i tell? I hope that is the problem cause it is an easy fix and would make me feel like an idiot.
