Need some help deciding which Modded H2E - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 09-16-2007, 05:26 AM Thread Starter
<- Sums it up
strokin_early_99's Avatar
Question Need some help deciding which Modded H2E
I am trying to decide between the 70mm/17cm and a 66mm/17cm version of the modded H2E.
Any input woud be appreciated. I tow so that is important. I am trying to see if anyone has run any of these two turbos.
I know Luke ran the 66mm. Thanks again Luke for all of the great info you have PM'd me and the call.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #2 of 30 (permalink) Old 09-16-2007, 11:12 AM
Haul_n_horses2's Avatar
Re: Need some help deciding which Modded H2E
How about posting the gist of it here so the rest of us can learn.
Haul_n_horses2 is offline
post #3 of 30 (permalink) Old 09-16-2007, 03:10 PM Thread Starter
<- Sums it up
Luke,
What size intake plenums are you running? What do you have done to the engine? And what do you dyno with your combo? I am looking for about the same setup as you. My biggest worry is I tow. I don't want to have EGT issues because the turbo won't spool.
Thanks,
Howard
Luke wrote:
When i was running the hybrid h2e, the engine had- 3" plenums, fully built engine, and dynoed 550rwhp with a stock hpop. Oh, the truck had 3.55 gears ('96 f250) and i still had no major problems towing with it. The truck weighed any where between 20k-24k gross, so it was defiantly getting worked out. If you have 4.10 or 3.73's i really think the turbo will work fine.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #4 of 30 (permalink) Old 09-17-2007, 02:05 AM
Wheelie Dude
bean's Avatar
Send a message via AIM to bean
Luke also has the 71. we have a larger turbine wheel for it now as well that should cure surge issues.
Smokin' Hot Hooker- 2002 F350 Dually 4x4 6spd- 5.9 CR-
BDP Drag Truck- 81 C10-5.9CR, BTS 4R, Goes Fast
Beans Diesel Performance
bean is offline
post #5 of 30 (permalink) Old 09-17-2007, 02:27 AM Thread Starter
<- Sums it up
71mm H2E? Or K31?
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #6 of 30 (permalink) Old 09-17-2007, 02:31 AM
Wheelie Dude
bean's Avatar
Its a 300 but 300 and H2 are real close to the same thing. Regardless the wheel is the same.
bean is offline
post #7 of 30 (permalink) Old 09-17-2007, 02:41 AM
uhh cost?
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #8 of 30 (permalink) Old 09-17-2007, 03:56 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Strokin- Isn't the 17cm housing stock for the h2e turbo? Seems to me with your b-codes you would need a little bigger housing wouldn't you? Or do you want to stick with the 17 for even quicker spool up?
Reason I ask is because I have stg1 injectors 3.55gears and 35inch tires and the spool up on my set up isn't bad at all, however I have such a bad exhuast leak at the up-pipe I have to turn the radio up to hear over it. Just picking your brain for the reason for your planned set up. Thanks Tyler
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #9 of 30 (permalink) Old 09-17-2007, 04:09 AM Thread Starter
<- Sums it up
17cm Stock exhaust housing for towing, ie...spool up. The modded H2E was recommended my Bean and Cale.
The sledscreamer and 71mm s300/k31 hybrid have a 19cm housing. My concern is surge and lag while towing. The modded H2 has no reports of surging while the others surge some.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #10 of 30 (permalink) Old 09-17-2007, 04:17 AM
Corona Killa
THEDIESELMAN's Avatar
Well it sounds like the modded H2E is the way for you to go.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
