4r100 converter lock up switch ?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 41 (permalink) Old 02-11-2013, 05:56 PM Thread Starter
go big or gooo home!!!
7.3lifteddiesel's Avatar
01 ford f250 7.3 wicked wheel cts programmer afe intake mrbp 4"turboback 7"mitre stack 8" superlift ssr shocks with remeote reservoir trac bars cowl hood chrome door handles billet grill road armor bumper tinted tail light and front windows 12" kicker cvx kicker amp
7.3lifteddiesel is offline
post #2 of 41 (permalink) Old 02-11-2013, 06:12 PM
woodduck97's Avatar
Re: 4r100 converter lock up switch ??
Nice post
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #3 of 41 (permalink) Old 02-11-2013, 06:32 PM
Old Yeller, REBORN
kilapapipa's Avatar
Welcome to guzzle's TC Lockup Mod Web Page
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #4 of 41 (permalink) Old 02-11-2013, 08:33 PM Thread Starter
i think its gunna be a lil harder than everybody says but i want this so bad !!!!! anybody got anything else maybe a lil easier explanation
post #5 of 41 (permalink) Old 02-11-2013, 08:40 PM
Village Idiot
southmike's Avatar
Look at swamps and or diesel innovations.
May have to search google etc their tech pages has moved.
southmike is offline
post #6 of 41 (permalink) Old 02-11-2013, 08:53 PM
Old Yeller, REBORN
kilapapipa's Avatar
Mount a toggle switch to your dash, ground one end of it. Run the other wire through the firewall and splice it into the wire on the diagram from guzzle's. I think it is purple/orange but I can't remember.
Done.
post #7 of 41 (permalink) Old 02-11-2013, 10:17 PM
there is a 12 pin connector on the passenger side of the tranny. the pin #4 has a purple wire with a yellow strip. this is the signal wire for the converter to lock up run a jumper from that wire to a switch from the switch to a ground and there ya go. i done it to mine and it works flawlessly. just rember to unlock it when you go to stop or u will kill your truck and possibly break something or rear end someone. remember not to cut the wire completly in half just peel back some of the insulation and just put a splicer on it
ibleeddiesel is offline
post #8 of 41 (permalink) Old 02-12-2013, 03:02 AM
how much of a benefit is there when you do this?
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, BTS
riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Hydra with GEARHEAD Tunes
lariat7.3 is offline
post #9 of 41 (permalink) Old 02-12-2013, 03:11 AM
You can save fuel. And you can drive on the highways a lot easier to when hauling pulling mountains no shiftng unless you have to. No shifting in an out of od when u are on the interstate and some dumbas flies by you and cuts you off then slows down then u have o slow down and hit brakes and shiftes out of od. And your tranny will run cooler
post #10 of 41 (permalink) Old 02-12-2013, 01:42 PM
Old Yeller, REBORN
kilapapipa's Avatar
I use mine when pulling a camper on a dirt road from 5000ft to 8000ft at speeds of 25-30mph. In most cases you are in 2nd gear but with the tc unlocked and that builds more heat than if the tc was locked up. The TC locks based on speed. In some cases when towing 45mph or so, it will lock and unlock which isn't good either so just lock it up and make it stay locked to prevent more heat.
Doesn't help any on the open road/highway. The TC is locked up anyway. Many people confuse the TC with overdrive. Just because you kick the overdrive off on the highway, you aren't unlocking the TC thankfully or you would really create some heat.
