Compression and Injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-10-2013, 02:09 PM Thread Starter
I bought a e99 a few months back knowing it had some problems, the PO had just replaced the injectors but unfortunately he used Diesel Care Performance. Using AE it always fails #3 and #8 CCT so I decided to dive farther into it since I needed to fix a valve cover leak and since I wanted to upgrade to a d66 and hybrids or stage 2 I decided to do a compression check to see what shape my motor was in. The results for the compression test are below, this is with using a harbor freight gauge I put together and I didn't have another one to compare the results too, elevation is 1,000 ft.
1. 320
2. 350
3. 340
4. 330
5. 340
6. 320
7. 330
8. 340
The truck starts fine and no smoke and when I bought it I tested it warm and didn't notice alot of blowby. I usually plug it in just to make warm ups quicker, after work when the oil is around 30 degrees I usually just wait about 5 seconds after the WTS light goes off and it fires right up within a few seconds. It wasn't cold today so I couldn't really test but oil was at 40 and as soon as WTS light went out the truck fired within a second.
Here is a video of disconnecting the injectors #3 didnt seem to make any difference unplugged or not and #8 seems to dump oil compared to some of the others.
7.3 injectors - YouTube
What do you think on the injectors seems to me like the 6 month old DCP injectors need replaced. Would anyone be worried about those compression numbers and stepping up injectors and turbo?
Thanks
cory99 is offline
post #2 of 9 (permalink) Old 02-10-2013, 03:25 PM
the stryker god
Re: Compression and Injectors
Those compression numbers are piss poor. Over 400 is ideal and about 360 is as low as i would want to run. Might be time for a overhaul.
bruce51d is offline
post #3 of 9 (permalink) Old 02-10-2013, 06:03 PM Thread Starter
They do seem low especially since it only has 105k on it. Wish I would have had another gauge to compare it to since it starts and runs just fine. I am pretty sure I need injectors regardless and the CCT test fails two of the cylinders with the highest compression. Was debating about going ahead and putting injectors/turbo on and run it for a while longer and overhaul later on possibly.
cory99 is offline
post #4 of 9 (permalink) Old 02-10-2013, 06:28 PM
jaybuller's Avatar
That's a little low. My 2000 with 157k on it are all within 5 psi and the lowest is 394
But it could be your guage or your setup?
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #5 of 9 (permalink) Old 02-11-2013, 12:11 AM
Old Yeller, REBORN
kilapapipa's Avatar
I would step up the injectors and turbo and run it til' it really does need an overhaul.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #6 of 9 (permalink) Old 02-11-2013, 04:40 PM
SledDogg's Avatar
Anything over 310-315 psi should fire off. Mine tested 325-350 about 200k miles ago. And I'm running it hard everyday towing all over the big grades out west.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #7 of 9 (permalink) Old 02-11-2013, 07:44 PM
jaybuller's Avatar
i agree with the above. id run it and not think twice.
post #8 of 9 (permalink) Old 02-11-2013, 09:39 PM
Village Idiot
southmike's Avatar
Id run it as is.....probably already am...lol
southmike is offline
post #9 of 9 (permalink) Old 02-12-2013, 02:07 AM Thread Starter
Thanks everyone I was thinking might as well start the upgrades and rebuild it later if that time ever comes especially since I only have a little over 4k into the truck.
cory99 is offline
