intake exhaust advice please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-09-2013, 02:37 AM Thread Starter
So I have an 01 f350 bone stock except for appearance. I am considering a 4" diamond eye tb exhaust with 5" tip and I believe he said a afe stage 2 intake. Exhaust work done for 500 bucks and intake for 400. My questions are is this reasonable, and will this gain me anything with the rest being stock, I have read conflicting stories. I was only planning to do these two mods and be done. Any thoughts would help.
dspowerstroke is offline
post #2 of 17 (permalink) Old 02-09-2013, 03:40 AM
the stryker god
Re: intake exhaust advice please
Diamond eye exhaust can be had for under 250 dollars and a diy intake is like 60. 900 for intake and exhaust is absurd
bruce51d is offline
post #3 of 17 (permalink) Old 02-09-2013, 03:47 AM Thread Starter
Well I'm not going to weld and hang exhaust myself so for that half of it is that still a rip? And what diy intake are you referring to? I am not knowledgeable about this stuff and looming for help.
post #4 of 17 (permalink) Old 02-09-2013, 07:01 AM
Its a DIY tymar intake it cost me about a 100 bucks. I bought a 4 inch 45 exhaust pipe and Donaldson 6637 from napa. Bought a 4 inch silicon coupling on amazon took me about a hour to cut and build looks good.
jeffmarble is offline
post #5 of 17 (permalink) Old 02-09-2013, 04:50 PM
The Diesel Cartel
InMotionJosh's Avatar
Send a message via AIM to InMotionJosh
There is no welding required for the exhaust. They are bolt on kits.
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #6 of 17 (permalink) Old 02-09-2013, 06:25 PM
scagle1's Avatar
If your not doing any big mods then just get it straight piped and buy a tip. Or for the money , straight pipe it $60 , 6637 intake $60 , JWVB $225 , and a custom tune $400. Still well under the $900 you were going to spend with a whole different truck. Oops gauges - need at least a pyro gauge if your towing or beating on it , a boost if you care to know it as well
03 7.3 with the new nose 8" and 37's 124k original and adding slowly
Sold - 00 X, 01 350, 02 350
scagle1 is offline
post #7 of 17 (permalink) Old 02-09-2013, 07:48 PM
go big or gooo home!!!
7.3lifteddiesel's Avatar
id say the same i have 4" turbo back and cold air its the best u can get but i have a out of this convo question how do i get a profile pic of my truck beside my name any help plz
7.3lifteddiesel is offline
post #8 of 17 (permalink) Old 02-09-2013, 09:02 PM
SledDogg's Avatar
I installed the 6637 directly to the STOCK rubber intake tube. Its going ti require some silicone spray and sometimes hook picks to get it on. Then I put three or four screws threw it to keep it together. Put stock hose/filter clamp back on. Might have to shave rubber guide nubs. I'm persnally sick of my 6637 and will buy s Bank's Air box set up soon. Sick of hearing the intake noise 12-18 hours a day. Also installing a Gen II Wicked Wheel or 38R and I don't want to hear it. Tired of buying a new 6637 every 4-6 weeks as well.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #9 of 17 (permalink) Old 02-10-2013, 10:29 PM
rfrostick's Avatar
afe stage 2 dry flow- AFE Stage 2 Cold Air Intake System with Pro-GUARD 7 Type XP 75-10192
you can do the diy intake system but you will be sucking in engine compartment air for the most part
2001 crew cab lariat
8" superlift suspension lift
38" toyo mt with 18" fuel hostage deep black wheels
afe stage 2 dry flow intake
2nd gen Wicked Wheel
ebpv delete housing
ts 6 position chip with Matts tunes
4" turbo back exhaust
3/8" fuel lines with baldwin fuel/water separator
rfrostick is offline
post #10 of 17 (permalink) Old 02-10-2013, 11:13 PM
SledDogg's Avatar
That AFE IS over priced and also sucks in hot air.
SledDogg is offline
