turbo boot issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-06-2013, 05:16 PM Thread Starter
turbo boot issues
anyone found a good set of boots, stockers were leakin, bought some aftermarket that immediately leaked, 2 didnt even fit. is stock the best option?
BurninMetal is offline
post #2 of 6 (permalink) Old 02-06-2013, 05:25 PM
the stryker god
Re: turbo boot issues
Dieselsite has some good ones, i think mine are from riffraff
bruce51d is offline
post #3 of 6 (permalink) Old 02-06-2013, 05:33 PM
7.3
7.3's Avatar
i was thinking about getting a set from riffraff. question about tightening the clamps on the plastic intercooler ends, can you crack them if you tighten too much?
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #4 of 6 (permalink) Old 02-06-2013, 06:07 PM
the stryker god
Yes. If you have problems with them blowin off spray them with hair spray
bruce51d is offline
post #5 of 6 (permalink) Old 02-06-2013, 07:55 PM
Village Idiot
southmike's Avatar
Dieselsite boots and hairspray should be the last set you ever need.
Solid top quailty units...though I would add the inserts to keep from Crushing intake plenums.
southmike is offline
post #6 of 6 (permalink) Old 02-06-2013, 08:15 PM
Dieselsite Barbie's Avatar
Thanks southmike! The kind words are always appreciated... however, we do not support the use of hairspray whatsoever for our boots. It is a chemical and will cause a reaction that breaks down ANY boot material. The reason it "helps" the boots stick is because you've just glued your boot to your pipe. This is why some people are forced to use screwdrivers just to pull their boot off and then end up putting a hole through it.
What we offer instead to keep people from blowing their boots are our retaining rings. Here's the description of them from our website:
"You have heard about "O-rings" for your heads. Now use the same idea for holding on turbo cac hoses in high boost applications.
Simply slip the stainless wire over the tube until it sits in the negative bead groove. Slip the boot over the pipe and install your clamp over the area where the ring now rests. Gives the strength of welding a bead on your pipe without the need to take your pipes to a welder."
Dieselsite Barbie is offline
