1997 F250 7.3 fuel filter housing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-06-2013, 04:27 PM Thread Starter
My fuel filter housing is leaking, it blew out during the summer. Ford wants $458 for a new one so I pulled it off boiled it and cleaned all up and then welded it back up (welding cast aluminum sucks!) but it held until last week now its leaking I've tried to find after market part but no luck. I've even considered by-passing it with a after market filter setup. But I'm not sure if that would work, if anyone has any ideas I would be very grateful.
Have a great day
oneshotonekill1966 is offline
post #2 of 4 (permalink) Old 02-06-2013, 04:50 PM
19stroker97's Avatar
Re: 1997 F250 7.3 fuel filter housing
You should move this to the obs section.
What exactly is leaking on it? O-rings, or your welds?
Have you checked a junkyard for another bowl?
If you wanna go to e-fuel there's a ton of options, just do a search.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #3 of 4 (permalink) Old 02-06-2013, 05:28 PM Thread Starter
I've checked junkyard all around, its not the o-rings or my weld its leaking on the opposite side. Whats e-fuel?
post #4 of 4 (permalink) Old 02-06-2013, 11:45 PM
Village Idiot
southmike's Avatar
1994-1997 OBS Power Stroke - Aftermarket Performance - PowerStrokeNation : Ford Powerstroke Diesel Forum
First post...
Whole section just on your truck...they shold add. 1999 and up on th title of this section.
I saw some on ebay...also a few get rid of them on here and might be one floating around for cheap..
If not call strickly diesel and dieselsite for options...strickky for filter and dieselsite for efuel..
Note e fuel is a whole system far superior to factory but costs a bit more...
southmike is offline
