WW2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 72 (permalink) Old 02-05-2013, 04:05 AM Thread Starter
TURBO LIT 'N' THAT WAS IT
powerstrokin7.3's Avatar
WW2
ok so i just ordered my new gen. 2 wicked wheel "WW2" I wanna see who else is using this and if there are any dislikes with it, everything i have seen so far has been nothing but positive
03 SCSB (TOTALED)
00 ccsb zf6, 4" exhaust, 6637, ts chip w/php tunes, tinted glowshift gauges, ats ported housing,RR, leveled, ccv mod, pp mod, zoodad, intake heater delete, ebpv delete, WW2, t-500, South Bend clutch, more to possibly come
powerstrokin7.3 is offline
post #2 of 72 (permalink) Old 02-05-2013, 02:47 PM
7.3
7.3's Avatar
Re: WW2
the only dislike was having to install it. other than that it functions flawlessly.
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #3 of 72 (permalink) Old 02-05-2013, 05:56 PM
Re: WW2
Mine is a little louder than i anticipated.
And heres some new info i logged today, hooked up a vsm to data log. Here is what we saw.
Baro..13.45
Ebp....13.5
A couple runs around his shop. These runs were with in 1 psi. From the screen shot comparisons.
2800 rpm
79% throttle
28 lbs boost (analog)
22 psi ebp (after correction)
Not bad for a stockish turbo. Less than 1 to1
UNDER PRESSURE is offline
post #4 of 72 (permalink) Old 02-05-2013, 08:43 PM
Village Idiot
southmike's Avatar
Re: WW2
lol...littleinvolved?
southmike is offline
post #5 of 72 (permalink) Old 02-06-2013, 01:39 AM Thread Starter
Re: WW2
lol, im an auto mechanic so hopefully this wont be too bad for me, it will be my first turbo project though.
And thanks for the inputs, cant wait to get this thing and see what it does
03 SCSB (TOTALED)
post #6 of 72 (permalink) Old 02-06-2013, 01:44 AM
Re: WW2
Not too bad, i didnt pull the turbo though. Used just the impact speed to pull the old wheel off....
post #7 of 72 (permalink) Old 02-06-2013, 01:47 AM Thread Starter
Re: WW2
thats the way i was planning on doing it, some ppl said you had to remove the turbo, but i didnt think you had too, should i use any lock tight or anything to put the nut for the wheel back on or is the few hits from the impact enough?
03 SCSB (TOTALED)
post #8 of 72 (permalink) Old 02-06-2013, 02:04 AM
Re: WW2
I started it by hand untill the the shaft starting spinning. Then hit it with the impact untill i could see the same number of threads protruding, which for mine is 3. I see no need for loctite etc. as the wheel tightens as it spins during normal operation. I seen a guy on youtube do it... I was just very careful holding the impact to not put pressure on the shaft.
I did however have to pull the top rear oil plug on the head to get my angle socket in and remove the bottom rear cover bolt, and had to remove the crank case vent box to fit the impact.
It maybe took me an hour with my buddy handing me tools while i laid on a sleeping bag acroos the top of the motor.
I turned the speed down when installing the new wheel, billet aluminum vs. a steel shaft may not be the ideal situation when using an impact. But it worked for me.
post #9 of 72 (permalink) Old 02-06-2013, 02:07 AM
Road Hammer
sniper_101's Avatar
Re: WW2
Don't Loctite!
I did when I rebuild my turbo back in August . . . it was not fun to put the Gen 2 WW on the other week, lol.
The wheel spinning is in the "tightening" direction of the threads, so no worries there about it coming loose.
00' F350 XLT - SCSB, 4x4, 6-spd
94' Ranger - 306/5-spd in progress
06' KTM 525 EXC-R - Dual sport & SuperMoto
sniper_101 is offline
post #10 of 72 (permalink) Old 02-06-2013, 02:20 AM
Sponsor
DIESELSITE's Avatar
Re: WW2
Please don't ever use an impact gun on a turbo. It causes tremendous stress on the shaft. I know it's a pain, but pull the turbo. If you hold the turbine wheel shaft with vise grips, you can unscrew the wheel very easily.
And like others posted.... Don't use lock-tite.
Bob
Bob Riley, Owner:
Proud Sponsor of Powerstrokenation.com
GOT DIESEL?ģ Tech Line 352-257-1669
DIESELSITE is offline
