turbo wastegate line - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-03-2013, 07:32 PM Thread Starter
Hello i have a early 99 f 250. a friend of mine told me you can take the wastegate line off to get better boost. i was just wondering your thoughts on it. thanks
stroker smoker 22 is offline
post #2 of 13 (permalink) Old 02-03-2013, 08:57 PM
the stryker god
Re: turbo wastegate line
It wont hurt anything, but you wont feel a substantial power increase
bruce51d is offline
post #3 of 13 (permalink) Old 02-03-2013, 09:51 PM
Village Idiot
southmike's Avatar
Removed the red line from wastegate solenoid - Power Hungry Performance Forum
Who is running a Turbo Master waste gate controller? - Page 2 - Ford Truck Enthusiasts Forums..
be ware without a chip or tunes you will not push high boost levels..
and that the pcm will defuel you at about 23lb unless the tunes ignore it or you have a boost fooler.
but get yourself a golf tee and try it if you like.
i have never messed with mine.
southmike is offline
post #4 of 13 (permalink) Old 02-04-2013, 02:37 AM Thread Starter
Thumbs up Re: turbo wastegate line
Do i need a boost fooler? I plan on putting an upgrade compresser wheel. Does anyone know where i can get a bigger compresser wheel that i can use the stock turbo housing?
post #5 of 13 (permalink) Old 02-04-2013, 03:46 AM
the stryker god
You can try the ww2 but you got to have fuel to make more power
bruce51d is offline
post #6 of 13 (permalink) Old 02-05-2013, 02:09 AM Thread Starter
What do u mean more fuel?
post #7 of 13 (permalink) Old 02-05-2013, 02:18 AM
the stryker god
Exactly what it says, more fuel either by tunin or bigger injectors. Fuel and air supplement each other but fuel is where it starts,
bruce51d is offline
post #8 of 13 (permalink) Old 02-05-2013, 04:19 AM Thread Starter
I do have tuning! Is the wicked wheel 2 an upgrade for a early 99?
post #9 of 13 (permalink) Old 02-05-2013, 04:53 AM
Village Idiot
southmike's Avatar
Should be..not as big as a d66 would be though..
But 1k difference too.
I have really given the ww some rhought but dont have a spare two hundred........yet
post #10 of 13 (permalink) Old 02-05-2013, 02:26 PM
Old Yeller, REBORN
kilapapipa's Avatar
If you have an early 99, you already have the WW(original). When I originally added the WW to my 2000, I lost 1-2lbs. boost by unplugging the red line to the wastegate.
Unplug it, see what happens.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
