POP QUIZ! what to do with auto shifter after ZF-6 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 01-31-2013, 02:01 AM Thread Starter
Freak'n know it all
gottagofast's Avatar
So I've swapped my auto out for a ZF and I have this shifter on the column staring at me... I found myself faced with the above question..... I came up with a KILLER solution!
More soon...........
BAWHAHAHAHA
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #2 of 20 (permalink) Old 01-31-2013, 02:27 AM
Cut it?
Sent from AutoGuide.com App
2000-7.3L is offline
post #3 of 20 (permalink) Old 01-31-2013, 02:36 AM
Powerstroke n00b
Justincredible's Avatar
Re: POP QUIZ! what to do with auto shifter after ZF-6 swap
get a manual steering column?...
1997 F-250 zf6, t-500 Hpop, Baby swamps, Beans D66 w/ 1.0, hydra, 6637 CAI, 6" exhaust. Kingpin D60
Boost, Oil pressure, HPOP Pressure, Water temp, Oil temp, Trans temp and EGT, fuel pressure
soon efuel and 3" plenums and intercooler.
Justincredible is offline
post #4 of 20 (permalink) Old 01-31-2013, 02:36 AM
the stryker god
Get a new steerin column
bruce51d is offline
post #5 of 20 (permalink) Old 01-31-2013, 02:37 AM
US Army
ArmyGuy45's Avatar
Is there a question?
US Army 2005-Present
2000 Ford F350 7.3L 4dr 4x4 long bed
NRA/SAF/AZCDL Life Member
"The role of Government is to protect equal rights, not to provide equal property." - Inspired by W. Cleon Skousen, The 5000 Year Leap.
The most important right is property rights. If you don't have the final say so with your property then what do you have?
ArmyGuy45 is offline
post #6 of 20 (permalink) Old 01-31-2013, 03:03 AM Thread Starter
Freak'n know it all
There WAS a bit of cutting involved.... on the cable..... a bit of welding and grinding and drilling also came into play.
I still have the same column.
yes there is a question.... I'll share the answer soon.... You guys are gonna LOVE this..... or maybe laugh at me but I don't care. I LOVE IT!
autometer gauges,
post #7 of 20 (permalink) Old 01-31-2013, 03:51 AM Thread Starter
Freak'n know it all
here's a BIG hint
autometer gauges,
post #8 of 20 (permalink) Old 01-31-2013, 04:00 AM
co04cobra's Avatar
I have a quick ? off topic. I always see guys say get manual column.
Do they mean actually replace the whole column? or just the black top cover piece? Im curious
Sorry for the derail. I am interested to see what you came up with.
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #9 of 20 (permalink) Old 01-31-2013, 04:06 AM Thread Starter
Freak'n know it all
well what "they" mean probably varies but you CAN just pull the lever and replace the plastic on top.
What I did was pull the plastic knob off of the steel lever and connect the cable inside my electric brake controller.
I welded up the column end of the knob to shape it so that it did not move forward and backward but only right to left.
I used a tiny cable stop to keep from over stroking and breaking stuff.... NOW when I pull the lever my trailer brakes apply proportionally to how far I pull it... they still also work automatically so all I have done is move the manual apply function from the controller to the column.
The trailer brakes will also now stay applied if I want until I push the lever back up... Functionality is just like a semi except electric instead of air.
I am currently shopping for a knob for the lever... the one pictured above is one of the candidates.
autometer gauges,
post #10 of 20 (permalink) Old 01-31-2013, 04:42 AM Thread Starter
Freak'n know it all
I DID run into one hitch... now I can't get the key out of the ignition... I'll get that fixed tomorrow tho.
autometer gauges,
