smoke switch on 99.5 7.3 powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-29-2013, 10:35 PM Thread Starter
PstrokeDiesel99
I have heard so many people say u can make a smoke switch on a 7.3 and probably the same amount of people say u cant. so im wondering if anyone has evwr suceasfully done it and how they did it.
PstrokeDiesel99 is offline
post #2 of 9 (permalink) Old 01-29-2013, 10:37 PM
the stryker god
Re: smoke switch on 99.5 7.3 powerstroke
gah everyone knows you wrap a walmart bag around your air filter if you want smoke you silly goose
bruce51d is offline
post #3 of 9 (permalink) Old 01-29-2013, 10:37 PM
444CuiOBS's Avatar
.....here we go!!
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #4 of 9 (permalink) Old 01-29-2013, 10:38 PM
Bugman's Avatar
You can't.
To make smoke you need to dump more fuel than air into the engine. So you would need a chip.
Prepare to get beaten up with this question.
Bugman is offline
post #5 of 9 (permalink) Old 01-29-2013, 10:51 PM
black_pstroke's Avatar
this method is WAAAAAAAAAY out dated man. The best thing is to take youre air filter off and duct tape the air tube inlet. You will black out towns and not need a smoke switch. Also If you wanna take things to the next level fill youre fuel bowl up with transmission fluid. You will be the envy of the whole diesel crowd with all the luscious coal you can roal!!!!! And both of these mods can be had for less than $10
2009 F-250 FX4 Icon, Toyo, Fuel, Bilstein, IDP/SCT, Flopro
black_pstroke is offline
post #6 of 9 (permalink) Old 01-29-2013, 11:19 PM
the stryker god
Drain all your crankcase oil and pour it in your fuel tank. Tons of smoke
bruce51d is offline
post #7 of 9 (permalink) Old 01-29-2013, 11:27 PM
Super Hauler!
Super_Hauler's Avatar
dumb! go somewhere. Get a can of diesel, then pour it all over the seats close all your windows except 1...crack it just a bit and light it on fire.
In all seriousness i hope your truck blows up so you cant drive it.
Super_Hauler is offline
post #8 of 9 (permalink) Old 01-29-2013, 11:35 PM
Rock Steady
When I am cruisin and wanna oralcoal I prefer to ignite some tires in between my unplumbed stacks in the bed.
no smoking permitted unless your hooked to a sled or sprinting the 1/4.
All about having fun but there is a time and place.
2000 F-450 Dump NLTD tunes
4duggan is offline
post #9 of 9 (permalink) Old 01-29-2013, 11:41 PM
OEM Moderator
Tom S's Avatar
This is going no where productive. Closed.
Tom S is offline
Closed Thread
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/148926-smoke-switch-99-5-7-3-powerstroke.html
Posted By For Type Date
Smoke Switch 7.3 Powerstroke_Yaelp Search This thread Refback 10-26-2015 07:05 PM
