Modifying the inlet/outlet of a cat - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-13-2007, 09:28 PM Thread Starter
thetonka's Avatar
OK with the thread on the cali smog checks possibly coming it got me thinking about the cat. I still have mine in there but if these smog checks are coming I am hesitant to get rid of it. So I have to wonder if it is legal to cut off the inlet and outlet and weld on 4" tube to mate up to a 4" exhaust. In theory it should still work and of course still be a restriction but would be better than stock.
I guess the other option would be to make it easily removeable but I think that would throw suspicion and unless you have smog check shop you trust I would worry about being report, especially since Al Gore created this whole global warming stuff.
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
thetonka is offline
post #2 of 14 (permalink) Old 09-13-2007, 09:35 PM
Re: Modifying the inlet/outlet of a cat
Are you a 6 speed? My truck doesn't have a cat. I'd tell em it didn't come with one
gregrob is offline
post #3 of 14 (permalink) Old 09-13-2007, 09:37 PM Thread Starter
thetonka's Avatar
Yup 6-speed, and I look at the tag on the valave cover and it says its supposed to have a cat. Mine is also the 275hp mill.
I have already solve the restriction problems with my cat, we had a talk and I won. I am thinking more along the lines of a visual inspection. Nowadays they run VINs and can tell from the VIN.
2001 F350 CC LB 4X4
thetonka is offline
post #4 of 14 (permalink) Old 09-13-2007, 09:39 PM
Move to Wyoming
gregrob is offline
post #5 of 14 (permalink) Old 09-13-2007, 09:42 PM Thread Starter
thetonka's Avatar
Aren't there gay cowboys up there?
2001 F350 CC LB 4X4
thetonka is offline
post #6 of 14 (permalink) Old 09-13-2007, 09:45 PM
Probably a few.
That was actually filmed in Canada BTW.
gregrob is offline
post #7 of 14 (permalink) Old 09-13-2007, 09:51 PM Thread Starter
thetonka's Avatar
Sure.
Anyway I am thinking what I can do is pick up a 4" DP, a prebent piece for over the rear axle and some straight 4". Cut the inlet and outlet off on the cat, weld on some 4" tube and put it all together. I would have my own 4" straight pipe with a 4" cat. Should work. Should technically be legal. At the least it oughta pass the visual and I can get programming to make it pass the sniffer.
2001 F350 CC LB 4X4
thetonka is offline
post #8 of 14 (permalink) Old 09-14-2007, 12:02 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
If you are going to tamper with it and remove the restriction here is an option.
If you want the visual effect of it still being on the truck just remove it and ream the guts out of it with a steel bar and a BFH (sledge hammer). It is full of a honeycomb type screen element. Then reinstall the gutted cat and you will have the visual effect.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #9 of 14 (permalink) Old 09-14-2007, 01:30 AM
Corona Killa
THEDIESELMAN's Avatar
But he wants to make it have a 4" inlet and outlet. the way I read it is will modding the cat to except 4" pipe will that make it fail the visual.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #10 of 14 (permalink) Old 09-14-2007, 01:51 AM
<- Sums it up
strokin_early_99's Avatar
All of this is not necessary. The cat on these things is a pass through. It looks like the inside of a glass pack muffler.
I found one here to go in when the time comes: http://www.4wheelparts.com/PDT34889.aspx
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
