a little face lift help please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-28-2013, 06:49 AM Thread Starter
Power_struck
Powerstruck99's Avatar
So my f350 has a little rack to it and I wanna make it sit level by raising the front up a couple in my question is will that mess up anything for steering/ axles etc? Thanks
Uhh well lett'r eat!!
99 f350 4x4
edge evolution
5 in stacks
Powerstruck99 is offline
post #2 of 11 (permalink) Old 01-28-2013, 08:07 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: a little face lift help please
just get a leveling kit and throw it on...
Ron's power stroke is offline
post #3 of 11 (permalink) Old 01-28-2013, 11:48 AM
the stryker god
You should adjust the trac bar but you don't have to
bruce51d is offline
post #4 of 11 (permalink) Old 01-28-2013, 12:39 PM
ΜΟΛΩΝ ΛΑΒΕ
GCncsuHD's Avatar
Year? 2wd or 4wd? That will make the difference on what you need and how to do it properly.
ΜΟΛΩΝ ΛΑΒΕ
2000 RCLB F250 6 speed XL work truck, work in progress
1978 Chevrolet K30 RC Dually 4" TC, 35" Kumhos, ex-firetruck
1967 Chevrolet C10 RCSB, 5.3 LS swap, resto in progress, in family since day one
1969 Chevrolet K5 Blazer, full convertible, family cruiser project
GCncsuHD is offline
post #5 of 11 (permalink) Old 01-29-2013, 01:38 AM Thread Starter
Power_struck
99 4x4 single wheel
99 f350 4x4
edge evolution
5 in stacks
post #6 of 11 (permalink) Old 01-29-2013, 04:11 AM
IL7.3 Powerstroker's Avatar
Send a message via Yahoo to IL7.3 Powerstroker
I bought a set of front spring hangers,ext length shackles and new rear lift blocks
All from Ebay total cost for 3.5" cost about $500, new Bilstein 5100 series shocks another $350 I am very happy with my new height!!
2002 F-350 Supercab longbed
AFE intake Bully Dog 5" exhaust
Swamps sticks, DP tuned
IL7.3 Powerstroker is offline
post #7 of 11 (permalink) Old 01-29-2013, 04:25 AM Thread Starter
Power_struck
I like the stock height but the front needs to sit level could I just block it up or would that be stupid?
99 f350 4x4
edge evolution
5 in stacks
post #8 of 11 (permalink) Old 01-29-2013, 10:40 AM
the stryker god
That would be stupid and dangerous. Get a spring pack or shackles if you want it done correctly
bruce51d is offline
post #9 of 11 (permalink) Old 01-29-2013, 11:49 AM
ΜΟΛΩΝ ΛΑΒΕ
GCncsuHD's Avatar
NO! I speak for the safety of everyone on the road around you, and the law.
Not every state, but most states have laws on the books prohibiting lift blocks on the front suspension.
Originally Posted by Virginia
Lift Blocks (46.2-1064):
"No motor vehicle whose front-end suspension has been modified by the use of lift blocks shall be driven on any highway in the Commonwealth."
Originally Posted by West Virginia
Lift Blocks (17C-15-48):
"Modification of the front end suspension by the use of lift blocks is expressly prohibited."
Originally Posted by Tennessee
Bumper Height/Suspenion Modifications (55-9-215):
"No person shall modify or cause to be modified by the use of lift blocks the front end suspension of a motor vehicle."
These are just a few I found with a quick search. Your front axle sees more leverage during braking and turning situations than the rear, so the front springs are more susceptible to damage by wrap or twist and the likelihood of breaking or spitting the blocks out causing you to lose control is greater, not to mention the effect on your steering geometry.
There are three proper ways of doing it, add a leafs, new leaf springs, or hangers and shackles. Add a leafs are the cheapest, but will make the ride noticeably stiffer, leaf springs are more expensive, but the change in ride can vary wildly from stiffer to softer than your stock springs depending on what code springs you had stock, and which company you go with for new springs, hangers and shackles are also expensive, right around or maybe a bit more than new leaf springs, and take more work to install, but they will keep the ride the closest to factory.
ΜΟΛΩΝ ΛΑΒΕ
GCncsuHD is offline
post #10 of 11 (permalink) Old 01-29-2013, 05:47 PM Thread Starter
Power_struck
wow thanks for the home work
99 f350 4x4
edge evolution
5 in stacks
