38R w/ 1.0 ar surging. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-27-2013, 11:02 PM Thread Starter
hyrk's Avatar
Is playing with the waste gate actuator adjustment gonna help my surging turbo when pulling loads? I've tossed the idea of the 1.15 around about 3 times already but the more I read the less I want one. Just thought maybe I could tinker to make the 1.0 work for me. Thanks.
Fyi I'm pulling at altitudes of 2100-2200 ft.
2002 F-350, S&B intake, 38R tubro w/ wwII, EBV delete, CFM manifold, Spearco i/c, Adrenaline HPOP, Casserly stage I AC injectors , ITP Reg. return, DI Headers, hutch fuel mod, Cooling mist stg. 3, 4" MBRP Exhaust, transflow 46 and 40 gal fuel tanks/tool chest, Tunes by GAP, 4" pc lift, 22" Tis 534 wheels w/37"x 13.5" Dakar MT's, 4.30 gears
hyrk is offline
post #2 of 10 (permalink) Old 01-28-2013, 12:31 AM
Old Yeller, REBORN
kilapapipa's Avatar
Re: 38R w/ 1.0 ar surging.
You may want to look into the WW2 for the 38r. I think I will due to the lag I have heard the 1.15 housing can cause.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #3 of 10 (permalink) Old 01-28-2013, 01:14 AM
Village Idiot
southmike's Avatar
ask csipsd aka joe...he had wicked problems with the 38r surging and was quite vocal on it a few banns later he calmed down and started even recommending it...iirc the 115 helped but pm .him and see.
southmike is offline
post #4 of 10 (permalink) Old 01-28-2013, 01:22 AM
duxpsd's Avatar
Ive heard good things about the WW2. Search on this sight for it there is some good info.
duxpsd is offline
post #5 of 10 (permalink) Old 01-28-2013, 07:36 PM
Village Idiot
southmike's Avatar
call bob at dieselsite..they are testing right now but his version is designed to eliminate surge and he has a prototype for the gt38r..so far all has gone well.
so the good news is this may end up with no surge for you the same or better boost numbers and more power..the down side is....is beta testing nothing is guaranteed so you may shorten the life of the turbo running it..it could tko the turbo or it could do nothing . it literally is in the r&d phase on the 38r..
now all of the units out being tested have done well and no one has had turbo issues..
this is simply a wheel change just like the ww1 and no one had issiues with that , so i think the chances are slim any damage would be done..just know that if it does no one is replacing your turbo..just saying. now the folks at dieselsite are some of the best in the bizz and upfront and very informative..so call and ask.
post #6 of 10 (permalink) Old 01-28-2013, 08:25 PM Thread Starter
hyrk's Avatar
Thanks all. Gonna look up ww2 and chat with bob.
hyrk is offline
post #7 of 10 (permalink) Old 01-28-2013, 11:29 PM
Village Idiot
southmike's Avatar
ask him about polished housing too
post #8 of 10 (permalink) Old 01-29-2013, 01:36 PM
I ran the 38R with the 1.15 housing and i was not all the happy with it. Still surged down low and was slower to spool. I would look elsewhere to try and solve your surge issue.
Curtsey
Early 99 Crew Cab,LB , 4" magna-flow exhaust, S&B Intake, FASS Pump, HRX, Regulated Return, Riff Raff Billet Plenums, ARP Studs, 910 springs, Chromoly Push rods, OBA, Carson Stuaffer t4 mount and a Borg warner s64.5 sxe Turbo, PIS 175/80's, T-500, ISSPRO EV2 Gauges, BTS Trans!
cjfarm11 is offline
post #9 of 10 (permalink) Old 01-29-2013, 07:09 PM
Layson's Avatar
Seems like the only time I had issues with the 1.0 housing was due to gearing. I had 37's and stock gears. Not enough RPM's and the turbo wasn't happy. You stay above the 1800 RPM range and you have a happy turbo. 38's and 4.30 gears, 1.15 housing and the turbo stays happy as long as the RPM's are up!
Layson is offline
post #10 of 10 (permalink) Old 02-07-2013, 07:30 AM Thread Starter
hyrk's Avatar
ww2 for 38r ordered. I'll let ya know how it works out.
hyrk is offline
