gt38r in early 1999 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 01-23-2013, 06:42 PM Thread Starter
I bought the garrett gt38r an need the parts from a late model 7.3. Anyone have know exactly what parts i need?
7.3strokin' is offline
post #2 of 27 (permalink) Old 01-23-2013, 06:48 PM
Re: gt38r in early 1999 7.3
pedestal, up-pipes, intake plenums, spider.
Curtsey
Early 99 Crew Cab,LB , 4" magna-flow exhaust, S&B Intake, FASS Pump, HRX, Regulated Return, Riff Raff Billet Plenums, ARP Studs, 910 springs, Chromoly Push rods, OBA, Carson Stuaffer t4 mount and a Borg warner s64.5 sxe Turbo, PIS 175/80's, T-500, ISSPRO EV2 Gauges, BTS Trans!
cjfarm11 is offline
post #3 of 27 (permalink) Old 01-23-2013, 06:50 PM Thread Starter
spider is the X pipe right?
post #4 of 27 (permalink) Old 01-23-2013, 07:22 PM
the stryker god
Need to just sell it and get a d66
bruce51d is offline
post #5 of 27 (permalink) Old 01-23-2013, 10:19 PM Thread Starter
why is tht? ball bearings in the gt38r spool faster then the journal bearings? and are much tougher
post #6 of 27 (permalink) Old 01-23-2013, 10:32 PM Thread Starter
also what is ebpv mean?
post #7 of 27 (permalink) Old 01-24-2013, 12:32 AM
19stroker97's Avatar
Bb turbos also cant be rebuilt as cheap or easy as a jb turbo. It means exhaust back pressure valve. It would be cheaper and easier to sell the 38r and get the d66 that way you can just bolt it on and be done.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #8 of 27 (permalink) Old 01-24-2013, 12:53 AM
the stryker god
with the money you'll spend on upgradin you could upgrade to a s366 on irates t4 and have a much better set up. lots have people have went from e99 to l99 stuff and wished they would have went the t4 route
bruce51d is offline
post #9 of 27 (permalink) Old 01-24-2013, 09:20 PM
fueled by Colecovision
golfer's Avatar
Garage
^agree...(unless you have a L99-03 7.3 donor engine available to swap parts from)
orrrr. you have a manual transmission, which might benefit a touch from the 38R over the S366...
but an S366 is tough to beat...just have to pony up for the mount.
golfer is offline
post #10 of 27 (permalink) Old 01-25-2013, 11:21 PM
Village Idiot
southmike's Avatar
pedestal comes in two flavors ebpv and non.
ebpv -exhaust back pressure valve is a warm up valve that closes..(the thing that makes your turbo sound hissy in the winter)
the delete simply eliminates it, some use it as a cheap brake, others remove it.
the uppipes are larger and longer..international makes a bellowed set for 400 ish..if you hasve to buy them the bellows leak less. Di has a one piece as well.
spider.is the x looking thing aka baby butt...sd is larger.
you can get the cfm+ system as an upgrade but not really worth it for the gains.
intake plenums are the long black tin looking things , two of them.
the hole is larger on the late models..wise upgrade are the re-enforcing rings that slip in and keep you from crusing them when you tighten down the boots.
you will also need various boots and clamps for the larger pieces.
dieselsite has by far the best as far as durability...well mr.bobs boots are great but omg $$. dieselsite bobs boots are great.
but if your looking for the best 38r type mount it would be bellowed up pipes, a cfm+ mount, some would sau ebpv delete pedi
southmike is offline
