wastegate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-22-2013, 04:12 PM Thread Starter
mtray's Avatar
wastegate?
Hey guys I am putting a ported compressor housing on my truck and was curious as to what would happen if i didnt put my wastegate back on. how would this affect the engine and the performance of the turbo? ive heard of it with the 1.15 housings but what would happen with the stock .84?
mtray is offline
post #2 of 5 (permalink) Old 01-22-2013, 04:53 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: wastegate?
to much back psi and heat if you go over 30lb of boost..if your good at keeping boost where it belongs then nothing will happen... hard to do when your racing or smoking the tires..better of depending on the gate to do its job...
Ron's power stroke is offline
post #3 of 5 (permalink) Old 01-22-2013, 07:13 PM Thread Starter
mtray's Avatar
Re: wastegate?
would a truck with stock injectors 6637 intake 4" exhaust and beans chip overboost?
mtray is offline
post #4 of 5 (permalink) Old 01-22-2013, 07:37 PM
Re: wastegate?
yes it will if you have a boost fooler in place... if it was me, I would run the turbo master..it will provide a more efficient boost ...or tighten yours and hope for the best...
1999.5-2003 Ford 7.3L PSD Wastegate Controller
post #5 of 5 (permalink) Old 01-22-2013, 08:00 PM Thread Starter
mtray's Avatar
Re: wastegate?
okay ill look into it. thank you very much for the info
mtray is offline
