dual sd pumps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-22-2013, 03:02 AM Thread Starter
dual sd pumps
does anyone have any write ups or anything on this really the only thing i need to i how to make the 2nd pickup in the tank
ibleeddiesel is offline
post #2 of 9 (permalink) Old 01-22-2013, 03:04 AM
the stryker god
Re: dual sd pumps
This is only one pick up, they both draw out the same one. Search dual pumps im sure there is plenty of literature on the subject
bruce51d is offline
post #3 of 9 (permalink) Old 01-22-2013, 03:07 AM Thread Starter
Re: dual sd pumps
ok thank you
post #4 of 9 (permalink) Old 01-22-2013, 02:02 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: dual sd pumps
You will need a bracket mostly.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #5 of 9 (permalink) Old 01-22-2013, 05:00 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: dual sd pumps
scroll about 3/4 the way down in this link,,
Maintain's Install Info..lots of good stuff here!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Ron's power stroke is offline
post #6 of 9 (permalink) Old 01-22-2013, 05:08 PM Thread Starter
Re: dual sd pumps
I have one ? How do I make a 5/8 pickup. And I'm haveing a hard time finding the right fittings
post #7 of 9 (permalink) Old 01-22-2013, 05:10 PM
Re: dual sd pumps
Driven Diesel 5/8" Fuel Tank Pickup
post #8 of 9 (permalink) Old 01-22-2013, 05:26 PM Thread Starter
Re: dual sd pumps
Thanls. How do I change the stock pumps from 5/16 to 3/8 or just reduce but reudceing will cause restriction right
post #9 of 9 (permalink) Old 01-23-2013, 12:22 AM Thread Starter
Re: dual sd pumps
where can i find a y fitting for 2 3/8 lines into the stock 5/16 i cant find one anywhere iv looked
