238cc/100% - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 01-17-2013, 10:13 PM Thread Starter
238cc/100%
hey im looking to put a set of stage 3 hybrids in my 7.3 with a stock fuel system im running between 60 to 65 psi of fuel pressure at wop with my stock injectors on the 140hp tune any ideas
ibleeddiesel is offline
post #2 of 14 (permalink) Old 01-17-2013, 10:18 PM
Re: 238cc/100%
Any ideas on what?
countryboyrob is offline
post #3 of 14 (permalink) Old 01-17-2013, 10:23 PM Thread Starter
Re: 238cc/100%
will the stock system hold up on a daily driver tune as in 400hp. the higher tunes will not be used intill the rr gets on it
post #4 of 14 (permalink) Old 01-17-2013, 10:26 PM
Re: 238cc/100%
Its all in how ya drive it, plus youll have to get the chip reburned for the single shots and the tuner can de-tune them
post #5 of 14 (permalink) Old 01-17-2013, 10:30 PM Thread Starter
Re: 238cc/100%
yeh no limit tuning as design in ten. is doing my tuning they are who does all of beans tuning. and he said that he can tune them down i was just curious to se it would keep up till i can get my RR cuz my stock injectors are gone. rosewood is doing the build on them now
post #6 of 14 (permalink) Old 01-18-2013, 01:03 AM
OBS Stroker
Nodge's Avatar
Re: 238cc/100%
I ran them for awhile on my stock obs system.
The highest 2 tunes would surge if you held the pedal down too long.
The other 4 tunes were no problem.
I should note it was a brand new stock replacement pump put in at the same time as the d66 and 238's.
You'll be fine for a little while if you can restrain yourself.
Just keep it out of the higher tunes or you could damage the plungers and barrels from bottoming them out due to the low fuel pressure.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #7 of 14 (permalink) Old 01-18-2013, 12:17 PM
Re: 238cc/100%
I just rebuilt my engine and put in a set of FFD 238/100s along with a T-500 HPOP and Driven Diesel fuel bowl delete RR. Running detuned in DD 80hp tune till I get a 38r turbo. Surprisingly it does not smoke unless I take off real hard from a stop and cleans up nicely. Don't notice the single shot hybrids being any louder at idle than the split shots. Runs smooth and has lots of power potential. You will like them.
As stated by the previous poster, you should be fine running detuned but you will definitely want to get a regulated return setup soon. I highly recommend the Driven Diesel kit. If you go the bowl delete route, plan on getting a post pump 2 micron filter to protect the injectors.
01 350 PSD CC 4x SRW
8" Coilover Conversion, 37x22 Toyo MTs
Factory Tech valve body, Billet triple disc TC, Trucool trans cooler.
Engine reborn 01/13, Forged Rods, ARP studs, Comp 910s w/ shims, Smith pushrods, FFD 238/100 sticks, T-500 HPOP, 38r, Airdog II, Driven Diesel fuel bowl delete RR, Fluidampr, PHP Hydra.
xenonx is offline
post #8 of 14 (permalink) Old 01-18-2013, 01:30 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: 238cc/100%
Are you upgrading the turbo as well or have you already? You may want to fill out your sig.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #9 of 14 (permalink) Old 01-18-2013, 10:38 PM Thread Starter
Re: 238cc/100%
yes im sorry i just now joined the psn but i havent still running a new stock turbo but will be geting new one in a while i am also purchasing the rr so i dont ruin a $2000 set of injectors also what is a good torque converter?
post #10 of 14 (permalink) Old 01-19-2013, 01:16 AM
the stryker god
Re: 238cc/100%
Pi stallion
bruce51d is offline
