Drive pressure readings? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-16-2013, 08:44 PM Thread Starter
jaybuller's Avatar
First off I have an areoforce scan guage that reads my ebp. Is this a reliable way to read drive psi? I'm trying to tune my setup and was wandering how y'all measure drive psi.. Are you guys running a pressure guage modded to handle the heat or just using the ebp sensor to determine the drive pressure? Thanks.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 5 (permalink) Old 01-16-2013, 09:24 PM
Re: Drive pressure readings?
reading your ebp can be reliable, but you need to take into consideration the baro for elevation you are at and subtract that from the reading.
You can run a 0-60/0-100 boost gauge, but need to replace the nylon tubing with either copper or ss. I have read where others have installed a small inline fuel filter (like for a lawn mower, etc.) to keep the soot from clogging the tube.
I'm sure more will buzz in on this shortly, hopefully someone can steer you in a better direction.
Edit: might also try ISSPRO, I thought I read somewhere that they sell an EV2 gauge that is actually labeled drive pressure.
xChrisHx is offline
post #3 of 5 (permalink) Old 01-16-2013, 09:44 PM Thread Starter
jaybuller's Avatar
Yeah I mean if the ebp sensor reading is reliable enough I will just use that. I used a boost guage on my 12v truck with the copper tubing as a heat sink but I mean I already have the ebp sensor giving me readings. Plus with the scan guage I can set it up so the map sensor is on top and the ebp sensor is on bottom to see the relationship between the two.
post #4 of 5 (permalink) Old 01-16-2013, 09:58 PM
Should be good to go with that setup...
I believe the ISSPRO's tap directly into the EBP sensor to get their reading, so....
I've never used a scan gauge, so I was kind of mis-reading our original post. I think you're good to go if it is reading from the EBP sensor.
xChrisHx is offline
post #5 of 5 (permalink) Old 01-17-2013, 02:11 PM
CGMKCM's Avatar
I think it should work fine, that is what the computer is using for input. I would make sure the EPB sensor is working correctly. Here is a trouble shooting guide from Oregon fuel injection that has the correct values for the sensor. Look under low power poor mileage.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
