S468 and stage 2s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 01-16-2013, 03:56 AM Thread Starter
Bird is the Word
Cloverleaffarm's Avatar
S468 and stage 2s
considering buying a S468 from Jake here in the future. wondering if anyone has experience with the charger and running Stage 2 injectors? truck is a work truck mainly that does alot of towing and daily driving as well. didn't know if it would be to laggy on the low end with that little amount of fuel for that size of charger?
E99<---Sold
07.5 CumminGs
ARP
Air Dog 2
Industrial Injection
Draconian Diesel TCM
Anarchy Diesel EFI Live
Cloverleaffarm is offline
post #2 of 37 (permalink) Old 01-16-2013, 04:57 AM
KB3MMX's Avatar
Re: S468 and stage 2s
Better off with a small hybrid injector than wasting your time with a stage 2.
Anyway,it should spool very nice even with 2s.
-08 F350 CC/SB
-S475 Billet turbo with .90AR housing @49PSI
-Elite custom aged Head studs
-Elite Valvetrain upgrade W/ Colt Cam (stage2)
-Black Maxx with MCC custom tuning
-SUNCOAST BILLET transmission W/ Precision TC
-Air Dog DF165
-Caltracs traction bars
-Detroit Locker
-Amsoil bumper to bumper
-BIG THANKS TO REIFF DIESEL!!
KB3MMX is offline
post #3 of 37 (permalink) Old 01-16-2013, 04:58 PM Thread Starter
Bird is the Word
currently am running 2s with my S366. got a good deal on them and didn't wanna pass them up. can still tear them out and sell them for a profit when necessary.
i'm afraid of having not enough fuel for a charger of that size and not having much low end towing
E99<---Sold
07.5 CumminGs
ARP
Air Dog 2
post #4 of 37 (permalink) Old 01-17-2013, 01:10 AM
Black 02's Avatar
You saw my response over on the army.
It's not gonna be bad. It will be a little more laggy than stock. It's a BIG turbo. Once it's lit, I could barely get my Stage II's over 1200 degrees at WOT with my race tune.
High gears and big tires will kill it. I know I could burn my truck up in OD pulling hills. It had the power, but the RPM's were so low that my boost was about 10 psi.
Not good when passing a Duramax!
Ryan
2002 Black F-350 4x4 Crew Cab LB Lariat
DP-Tuner F6, Irate T4, S468, T-500, 910's, AFE Intake, MBRP Stainless 4" Exhaust, Riffraff OCR, Casserly Stage II's, Riffraff FRx, Rebuilt 4R100 w/ Suncoast Triple Disc Converter, 6.0L Trans Cooler. 37x12.50R16.5 Super Swamper Trxus MT's w/ 6" Icon Lift. Locker Front & Rear w/ Heavy Duty Warn Hubs
Black 02 is offline
post #5 of 37 (permalink) Old 01-17-2013, 02:40 PM Thread Starter
Bird is the Word
it just sounds like alot of charger for the 2s to spool without alot of lag or slow response when climbing a hill.
i might just hold off on the turbo right now. finish getting the studs/springs/rods and internal mods put them on the shelf. then get the 250s and decide on which nozzle size would be better for a 468 so i can tow with it. and then add it all in at the same time
E99<---Sold
07.5 CumminGs
ARP
Air Dog 2
post #6 of 37 (permalink) Old 01-17-2013, 05:28 PM
OBS Stroker
Nodge's Avatar
I have a 468 but haven't installed it yet.
I'll try to remember to post up my results with 238/100's when I finally get around to installing it.
If I'm not happy, I plan to go with 300/200's.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #7 of 37 (permalink) Old 01-17-2013, 05:53 PM Thread Starter
Bird is the Word
i'd appreciate your results with the hybrids and how it runs.
E99<---Sold
07.5 CumminGs
ARP
Air Dog 2
post #8 of 37 (permalink) Old 01-17-2013, 06:44 PM
Black 02's Avatar
I didn't have an ounce of problems towing in Drive. I also talk about passes. These are somewhat steep. Not gentle slopes by any means. You know, the ones where the big rigs are doing 30 mph with the flashers on.
Ryan
Black 02 is offline
post #9 of 37 (permalink) Old 01-18-2013, 04:19 AM
19stroker97's Avatar
When you gonna put that thing on? It's been a while since I seen a post saying you got it!
Sorry for the derail, op.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #10 of 37 (permalink) Old 01-21-2013, 02:07 AM
Joeyd61's Avatar
I am running the S468 with 238/100 FF injectors and am really liking the set up. 1st, i tried the .90 exhaust housing and the low end and towing was great ,but EBP @ WOT was through the roof, changed back to the 1.10 housing, lost a little on the bottom but picked it back up on top and eased off the EBP
2003 F250 7.3 PSD Lariat,fresh forged rod motor,Full Force 300/200 Hybrid injectors,Terminator Dual HPOP,BW S468 turbo w/race cover,Isspro Guages,BTS Trans,XRF front end,Red Head steering box, Yukon 4.56gears,6" BDS lift,AD 150 w/sump,Walbro pump,SD Regulated Return,DP tuner Live Tuned,armed with Infinity and on & on & on
Joeyd61 is offline
