questions before i buy - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-14-2013, 03:42 AM Thread Starter
what is the best way to go. update my e99 7.3 turbo, idm and injectors to 2000 specs. or do a swamps street package, which is 175/146 injectors, a ts chip, regulated return , and a post pump filter? any help is appreciated
texasboy91 is offline
post #2 of 11 (permalink) Old 01-14-2013, 03:44 AM
Super Hauler!
Super_Hauler's Avatar
Re: questions before i buy
whats your plans for the truck?
Super_Hauler is offline
post #3 of 11 (permalink) Old 01-14-2013, 04:06 AM Thread Starter
i just want to go a lil better than stock.
post #4 of 11 (permalink) Old 01-14-2013, 07:53 AM
jtgf250's Avatar
Exhaust and intake is better than stock. Depnds on how much better you want. Regulated return is always an improvement as well as turbo. If your planning on injectors gonna need a chip also, and depending on what size injectors you may need a better HPOP.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 11 (permalink) Old 01-14-2013, 02:24 PM
biggin2001's Avatar
Depending on how much money you Want to spend really depend on how much better than stock your gonna go. If you don't need the extra power for what your doing with it I would get and intake exhaust and Tuner then leave it alone. To me after you upgrade your injectors your gonna keep finding yourself wanting more and when you get to the point of needing a bigger hpop to run your injectors it gets pretty expensive pretty quick.
biggin2001 is offline
post #6 of 11 (permalink) Old 01-14-2013, 07:31 PM Thread Starter
for either way it's gonna run me around $3500. I'm just lookin for a Lil more power and mpg
post #7 of 11 (permalink) Old 01-14-2013, 07:39 PM Thread Starter
yeah I'm finding out how expensive it can be. I got a new hpop on it. and I got a couple injectors not hittin right.
post #8 of 11 (permalink) Old 01-15-2013, 12:44 AM
Village Idiot
southmike's Avatar
first of all the best update to an e99 is get a new cup holder...hands down my favorite upgrade.
the next best was a pmt pcm since mine was an auto.
followed by the chip.
your airbox probably has broken tabs and needs to be replaced..i recomend s&b afe2, ford ais or a napa 6637 type.
realistically unless your injectors are done i would do a chip intake and exhaust first.
have a look at a d66 turbo from beans. and ask swamp or bean about that comboed with that turbo.
otherwise i would go straight to a h2e or qssb style turbo and mount.
100% waste of cash to get a 1999.5 turbo setup even with a gt38r for an early 99
southmike is offline
post #9 of 11 (permalink) Old 01-15-2013, 07:48 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
kicking my self in the ass for doing the 99.5 swap...i gained nothing more then what I already had..just a lighter wallet...the 99.5 really does not have much up on the E99....now im changing everything again..
Ron's power stroke is offline
post #10 of 11 (permalink) Old 01-16-2013, 02:10 PM Thread Starter
would doing the swap improve my mpg? thats mostly what im after but with out breaking my already light wallet
