WWG2 Test - Stock F350 Dually - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 46 (permalink) Old 01-13-2013, 08:49 PM Thread Starter
Forged rods R 4 SISSIES!
PowerHungry's Avatar
Here are some more test results of testing with the WWG2. The test vehicle is as follows:
2003 F350 CC, Dually 4WD, VDH5 (TNAA7S3), 230K miles, Injectors and HPOP replaced 6 mos. ago. Otherwise, the truck is completely stock.
As usual, testing was with 8000 Lbs load on the dyno. All runs we competed in 3rd gear locked. Speed was held at a steady 1400 RPM until full throttle was applied. Data sampling was taken from 1500 RPM to 3500 RPM. All testing was achieved with engine and transmission at normal operating temperature with 70 ambient air temp. All runs were datalogged to obtain boost and backpressure readings, along with monitoring EOT, ICP, IPR, and other critical data. Unfortunately, this vehicle was not equipped with a pyrometer so we were not able to observe any changes in EGTs. Datalog pressures were verified with a mechanical boost gauge and are considered to be accurate with +/- 0.25 PSI.
Generated results are as follow:
Stock ECM calibration (minus Speed Limiter and Rev Limiter) - Stock wheel vs. WWG2
Boost:
  • Stock:
    • 7.8 PSI @ 2000
    • 14.3 PSI @ 2500
    • 16.2 PSI @ 3500
  • WWG2:
    • 7.5 PSI @ 2000
    • 14.7 PSI @ 2500
    • 19.8 PSI @ 3500
Backpressure:
  • Stock:
    • 11.9 PSI @ 2000
    • 23.9 PSI @ 2500
    • 31.1 PSI @ 3500
  • WWG2:
    • 10.6 PSI @ 2000
    • 23.3 PSI @ 2500
    • 33.5 PSI @ 3500
Dyno Graphs:
(Click on image to enlarge)
Overall Gains:
Standard PHP 40 Tow - Stock wheel vs. WWG2
Boost:
  • Stock:
    • 8.6 PSI @ 2000
    • 15.0 PSI @ 2500
    • 18.5 PSI @ 3500
  • WWG2:
    • 7.8 PSI @ 2000
    • 16.2 PSI @ 2500
    • 23.8 PSI @ 3500
Backpressure:
  • Stock:
    • 13.4 PSI @ 2000
    • 24.7 PSI @ 2500
    • 35.5 PSI @ 3500
  • WWG2:
    • 10.2 PSI @ 2000
    • 23.2 PSI @ 2500
    • 37.4 PSI @ 3500
Dyno Graphs:
Overall Gains:
Overall Gain - Stock ECM/Stock Wheel vs. PHP 40 Tow Calibration/WWG2
Dyno Graphs:
Overall Gains:
We will be testing another S/D vehicle later this week (Friday) and will post up those results as well as they become available.
Bill Cohron - (678) 890-1110
- The Original in Custom Ford PSD & Gas Tuning since 1997
FOREVER
2001 7.3L - Stage 1's and a Tymar - 399 HP
2004 6.0L - 440 HP #2 Only/482 HP on Boost Juice - 12.961 @ 102.6 MPH
PowerHungry is offline
post #2 of 46 (permalink) Old 01-14-2013, 05:25 PM
Jeremiah25's Avatar
Re: WWG2 Test - Stock F350 Dually
Awesome results. How did the stock compressor wheel look with 230k?
2000 F-250 4X4 Crew Cab Short Bed Lariat
DIY 6637 intake
4 in down pipe 5 in straight pipe
PHP Gryphon Programer
Adrenaline HPOP
38r w/ Wicked Wheel 2
Bellowed up-pipes
Trans-Go Tugger Kit w/ billet converter
Jeremiah25 is offline
post #3 of 46 (permalink) Old 01-14-2013, 07:16 PM Thread Starter
It was actually pretty well worn, like someone ran a cheap filter for a while. Edges of the fins were a little worn, although no chunks were missing. New wheels definitely was a smart move, regardless.
FOREVER
post #4 of 46 (permalink) Old 01-14-2013, 10:54 PM
The Dude
OVERKILL#1's Avatar
How difficult is it to swap wheels?
OVERKILL#1 is offline
post #5 of 46 (permalink) Old 01-14-2013, 11:21 PM
the stryker god
Get on youtube and search wicked wheel install
bruce51d is offline
post #6 of 46 (permalink) Old 01-15-2013, 03:04 AM Thread Starter
Experienced folks can easily swap in less than 2 hours. First timers, maybe 4 hours. The V-Band clamp on the up-pipe spider is a pain to get off, but lots of PB Blaster, a flat blade screwdriver, and a few choice words will usually help it come right off. Everything else is pretty straightforward. Make sure to not forget the EBV control rod below the exhaust housing. You'll go to yank the turbo off and start cussing because you missed it. It has a snap clip (with a right angle tab) which holds the actuator rod onto the EBV control arm. With a small screwdriver or pair of needlenose pliers, slide the clip TOWARDS the turbo pedestal to release the actuator rod. When reinstalling the turbo, make sure to line up the actuator rod with the EBV control arm BEOFRE bolting the turbo in place. Otherwise it's a real bugger to bet back on the pivot for the EBV control arm.
FOREVER
post #7 of 46 (permalink) Old 01-16-2013, 05:55 PM
<---Peggy Sue
moose7.3IH's Avatar
i want one!!!
e99 f350cclb lariat 4x4 zf6 ranchhands
leveled
4" dp 5" straight pipe
ccv mod
cai
Rosewood 180/100 single shots
Terminator t500 hpop
Garrett 38r with all the late 99 goodies
Currently
79 bronco 400m c6 8" lift 5.13s welded rear Detroit locker up front 38.5" tsls for the trail 35" bogger/buckshots for the mud bogs
moose7.3IH is offline
post #8 of 46 (permalink) Old 01-16-2013, 07:30 PM
^^ what he said !
bill: when are you going to start selling them ?
Rilli_Chefen is offline
post #9 of 46 (permalink) Old 01-16-2013, 08:22 PM
PSD
CNDiesel's Avatar
Ive been to about 10 dyno days and seen chipped sd 7.3s make more then those numbers with the factory wheel. Gaining boost doesn't mean more power, you could port the heads and you'll loose boost but you won't loose power.
Not saying this isn't worth it but considering how cheap new compressor wheels are just for a turbo, 20-60 bucks. But when diesel is put in front of turbo it becomes a $200+ wheel. Just a big cash grab. Get enough advertising talking how great the snuggie is, when it is still a robe you put on backwards.,
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #10 of 46 (permalink) Old 01-16-2013, 08:39 PM
jaybuller's Avatar
Well of coarse you've seen chipped trucks make more...but I bet they weren't duallys running only a 40tow tune....
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
