EGT Probe Location Idea - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 01-13-2013, 01:54 PM Thread Starter
Renegade Diesel
Renegade7.3's Avatar
I know most guy puts the EGT probe in the end of the exhaust manifold. But i was wondering how much different would it be if you drilled and tapped the collector pipe that feeds the turbo. I would think it would get more of accurate reading from a mix of both sides of the engine.
Then again it could be a terrible idea but i wanted to throw the idea out there at least for discussion
Diesel Tech in Ohio
E99 7.3L 6spd 4x4 Lariat
AFE 4" DP back straight pipe
Built in Kentucky!
340,000 miles
"wear your high mileage as a badge of honor"
Originally Posted by dieselboy01 View Post
its a 7.3 thing, you wouldn't understand.
Renegade7.3 is offline
post #2 of 31 (permalink) Old 01-13-2013, 02:03 PM
Re: EGT Probe Location Idea
Its far much easier to just drill and tap the exhaust manifold.
countryboyrob is offline
post #3 of 31 (permalink) Old 01-13-2013, 03:29 PM
Super Hauler!
Super_Hauler's Avatar
if you want to pull the turbo, then get a drill in there go head. If you pull the collector they are a pain sometimes to align back up with the dowel. I would just drill/tap the driers side manifold. you will get relatively the same temps
Super_Hauler is offline
post #4 of 31 (permalink) Old 01-13-2013, 03:35 PM Thread Starter
Renegade Diesel
okay thanks,
the reason i ask is that im pulling the turbo to remove the EBPV soon and put new orings since its leaking and i was just curious as to wether there is any disadvantage or advatage to this location
Diesel Tech in Ohio
Built in Kentucky!
340,000 miles
post #5 of 31 (permalink) Old 01-13-2013, 03:50 PM
'05 Excursion
Term3's Avatar
The further away the EGT probe is away from the exhaust valves the more inaccurate it will be. A probe closer to the turbo will be affected by how much the exhaust cools as it goes up to the turbo which will very by how much air flow is going through the engine compartment at a given mph cooling off those up-pipes. If you ever put a truck on a dyno turn off all the shop lights and look at the engine I'll bet you'll say "Holy CRAP"!!!
Sent from my iPhone using AutoGuide.com App
Term3 is offline
post #6 of 31 (permalink) Old 01-14-2013, 02:24 AM
You want to be as close to the cylinders as possible. The farther you are away, the less accurate your reading becomes.
post #7 of 31 (permalink) Old 01-14-2013, 04:20 AM
Butt-Head
PHPDiesel's Avatar
On a stock turbo (or stock replacement turbo), the exhaust from each bank of the engine is kept separate all the way through the volutes of the turbine housing.
In other words, you'd STILL only be reading one bank.
Cody
PHPDiesel is offline
post #8 of 31 (permalink) Old 01-14-2013, 07:46 AM
jtgf250's Avatar
X4 closer to the cylinders the better and more accurate.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #9 of 31 (permalink) Old 01-14-2013, 10:54 AM Thread Starter
Renegade Diesel
Couldn't you gut that? Would it increase flow?
Diesel Tech in Ohio
Built in Kentucky!
340,000 miles
post #10 of 31 (permalink) Old 01-14-2013, 11:44 AM
ColeTrain45's Avatar
i had always thought the outlet of the the turbo on the dp?? if i'm taping and probing manifolds i would do both and have two gauges....
ColeTrain45 is offline
