ceramic coat - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-13-2013, 01:03 AM Thread Starter
User Error
buck90's Avatar
ceramic coat
Has anyone tried this on the exhaust parts? manifolds, up pipes, turbine housing (prolly not that one), down pipe? what's the going rate? every site says call for pricing, obvious on that one. If not, how about heat wrap? trying to lower underhood temps and keep exhaust pipe heat sink near the transmission low as possible.
I work with people entrusted to maintain and repair $110 million airplanes, but can't change a car battery.
2001 F250, Floyd's Stage 3 trans, GTP38R, aFe Stage 2 intake, TS Performance 6 position, 5" Diamond Eye straight turbo-back, 6" Pro Comp lift, 36" Nitto Terra Grapplers
buck90 is offline
post #2 of 13 (permalink) Old 01-14-2013, 01:25 AM
Re: ceramic coat
I had Jet Hot coat my bellowed up-pipes and downpipe. It cost $195.00 shipped to have the the pipes done in "extreme sterling". I believe this coating may only be good to 1300, which for me is plenty. You could go with the 2000, but that coating was only available in matte colors. I wanted a polished finish. I would recommend a color other than black on the up-pipes. This way you can see if there is any exhaust leak. If I ever need new manifolds, I will likely have them coated. With Jet-hot, you measure the length of pipe and they will give you a good estimate. I remember being very pleased.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #3 of 13 (permalink) Old 01-15-2013, 12:45 AM
Village Idiot
southmike's Avatar
Re: ceramic coat
yes lots of people have done it good results.. a few guys even sold oem mani's coated.
southmike is offline
post #4 of 13 (permalink) Old 01-15-2013, 03:01 PM Thread Starter
User Error
buck90's Avatar
Re: ceramic coat
sounds good. i was gonna have everything but manifolds done. id do them too but i doubt ill get them off without drilling and tapping at least 3 studs. you prolly cant do a turbo exhaust housing could you?
buck90 is offline
post #5 of 13 (permalink) Old 01-15-2013, 03:41 PM
SledDogg's Avatar
Re: ceramic coat
Most retailers offer a exhaust housingfor ceramic option if you buy a turbo. Usually $40-130 extra. Have seen posting of guys getting the new Dorman bellowed up pipes coated for $100.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #6 of 13 (permalink) Old 01-15-2013, 03:57 PM
CGMKCM's Avatar
Re: ceramic coat
Not sure where in NC you are located, Jet Hot has a large facility near Burlington, NC. Could save $$ dropping off instead of shipping.
I have not read anything on before/after under hood temperatures and if under coating is worth the $$.
I have an ATV with an after market exhaust that will melt plastic and your leg. I looked into getting it coated but everything I read was performance benefits and not how effective it would be as an thermal insulator.
Insulating pads, tape etc may work better.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #7 of 13 (permalink) Old 01-15-2013, 04:18 PM
the stryker god
Re: ceramic coat
Waste of money
bruce51d is offline
post #8 of 13 (permalink) Old 01-15-2013, 04:23 PM
Re: ceramic coat
Anyone have any pics of a truck with this done?
Davidmackv is offline
post #9 of 13 (permalink) Old 01-15-2013, 05:13 PM
Re: ceramic coat
I was under the impression that insulating tape could result in rot. The ceramic coat should make the pipes much cooler to touch. I did it to keep everything nice and clean looking. I would do the manifolds for this reason and the idea that it will keep them cooler to the touch. I would not expect any performance benefit.
post #10 of 13 (permalink) Old 01-15-2013, 08:44 PM
CGMKCM's Avatar
Re: ceramic coat
I think you are referring to header wrap and I can see why that may trap stuff that would lead to corrosion. I was talking about something like this.
http://www.heatshieldproducts.com/pr...t-shield/50/21
I would love to see before and after data on what ceramic coating will do to reduce under hood and cab heat.
[SIGPIC][/SIGPIC]
BTS Tranny
PHP Phoenix chip
Adrenalin
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
