Pcm issues on a 2002 7.3 anyone have problems?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-12-2013, 08:47 PM Thread Starter
AZmike's Avatar
My truck went to the dealer last week because I couldn't figure out the reason why it kept dying while driving. Then it finally just decided not to re-start at all. After a short time at the dealer it was determined that the power-train control module (pcm) was fried! Once that was replaced there where no other issues. The question I have is, I have a 4 step ts performance chip piggy backed on the pcm could this be the cause of my problem? I would assume ts performance would not produce something that would damage the factory computer so I'm concerned about using it on the new pcm.
Has anyone else had pcm problems on the 7.3?
This truck is a slug without the chip installed, is there something i could use that doesn't stay plugged in to the pcm?
AZmike
2002 Ford F350, Chip, exhaust, intake, 4" inch lift, 35's, 2007 front clip, stereo, blah, blah, blah..
AZmike is offline
post #2 of 5 (permalink) Old 01-12-2013, 08:49 PM
Re: Pcm issues on a 2002 7.3 anyone have problems??
AZmike
I have an 02 and my truck is no slug....
Only way the chip could have caused problems is if was installed wrong or pulled out while driving or was loose.
countryboyrob is offline
post #3 of 5 (permalink) Old 01-12-2013, 09:00 PM Thread Starter
AZmike's Avatar
The chip gets pulled out once a year for the annual smog check that's it. I just don't want to buy another pcm from the dealer!
Without the chip my truck just feels super slow and the shift point are sloppy, I'd prefer chipped up performance especially when I need to tow!!
AZmike
AZmike is offline
post #4 of 5 (permalink) Old 01-12-2013, 09:17 PM
I hear ya.....
post #5 of 5 (permalink) Old 07-26-2017, 09:25 PM
have a 2002 F350 7.3 diesel. the check engine light comes on and it starts cutting out just like an injector is not working it will do it for awhile then it will run fine then it does it again I am getting a code of p603 have cleaned the battery terminals and taken the heavy tow program out. I was told it could be the PCM that is causing this
dravel is offline
