Beans Tunes Problems no throttle response?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 01-12-2013, 03:49 PM Thread Starter
I have an E99 SD and just installed a couple of mods that i got from BDP. I went with single shot stage 1's a D66 and a ts 6pos chip from beans. Truck seems to run ok in stock and econo tunes (idles a little rough, kinda lopes a little) but daily tow and hot tunes are having issues. Whisper was workin fine but now doesnt seem to be workin as well after disconnecting the batteries. When I switch to daily tow and hot tunes at idle the truck idles down real low and has barely any throttle response but once the rpms are above about 1500 the truck will really go! The problem seems to be only at those low rpms. Wondering if it could be an oil or fuel pressure issue or a tuning problem? Any advice would be appreciated!!
Astroker99 is offline
post #2 of 21 (permalink) Old 01-12-2013, 04:52 PM
Re: Beans Tunes Problems no throttle response??
I would call Beans first.
2003 RCLB 7.3 Auto
4" Lift, 35" BFGs, Full Built Suncoast, 6.0 Cooler, Swamps IDM, DP F5 (80,120,140), intake, exhaust, gauges, etc...
More to come soon...
ewatts2003 is offline
post #3 of 21 (permalink) Old 01-12-2013, 06:38 PM
No need for more than one thread..... Just call beans.
countryboyrob is offline
post #4 of 21 (permalink) Old 01-12-2013, 06:59 PM Thread Starter
Already did and have been waiting to hear back from them. I Figured if anyone had any info on the situation, it could help me figure it out if its not a tuning issue.
post #5 of 21 (permalink) Old 01-12-2013, 08:41 PM
the stryker god
Jonathan ( bean's tuner) has his own business. No limit tuning iirc. Might want to try there
bruce51d is offline
post #6 of 21 (permalink) Old 01-12-2013, 08:43 PM
Village Idiot
southmike's Avatar
on my ts tunes my idle is lower in the top tune by 100 rpm or so.
your truck is an auto correct?
(sometimes the throttle position sensor wears in the sticks)
southmike is offline
post #7 of 21 (permalink) Old 01-12-2013, 11:42 PM Thread Starter
Would that cause the lack of throttle response under 1500 rpm. I can mash it to the floor and barely anything happens till it hits 1500.
post #8 of 21 (permalink) Old 01-13-2013, 01:13 AM
International Diesel Tech
purplepstroke's Avatar
I have an e99 and have the same problem as well with my stage 1s and there tunes. I talked to them about it and they said I will have to come down for a custom tune. Interested if you can get it figured out. However mine runs good with swamps tunes.
E99 7.3***230/100 PIS sticks***swamps tuning*** 4" mbrp***t500 HPOP***6637 filter***BTS valve body***racerx torque convertor***di reg return***walbro fuel pump***20x10 fuel hostages with Nitto 305 terra grapplers
purplepstroke is offline
post #9 of 21 (permalink) Old 01-13-2013, 01:47 AM Thread Starter
Im in Florida so goin there is not an option!! So you had beans tunes with the same issues and switched to swamps tunes with no problems? How do you like their tunes?
post #10 of 21 (permalink) Old 01-13-2013, 05:42 AM
Actually had the swamps tunes before and tried theres out for the heck of it. The swamps tunes are pretty decent. Just out of curiousity do you have the xle4 pcm too.
