Why not - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 01-11-2013, 01:52 AM Thread Starter
jdubb823's Avatar
Why not
I've looked and looked. Why doesn't anyone offer a 6.0 style intercooler with upgraded pipes, boots, and clamps? I want to up grade my set up, but don't want to keep my stock pipes.
2002 F350 SRW CC
20x10 XD Hoss, 35's, 05 suspension and axle swap, 05 clear headlights with 55w 6k hids(for sale).
Project DUBBLUP
jdubb823 is offline
post #2 of 22 (permalink) Old 01-11-2013, 02:00 AM
Village Idiot
southmike's Avatar
Re: Why not
banks is the only one i have seen with pipes..
tho A spearco will out perform it with stock pipes as will di'S offering.
maybe call banks and see how much just the pipes can be had for
for the record the most drop a 6.0 cooler will do is 150 though most see 25-50 or nothing depending on conditions.
more or less if you can get A 6.0 ic for free or 100$ i would say it is worth the scratches on your arms you will get from the swap.
just my two cents
southmike is offline
post #3 of 22 (permalink) Old 01-11-2013, 02:07 AM Thread Starter
jdubb823's Avatar
Re: Why not
Isn't a upgraded 6.0 better than a upgraded 7.3?
2002 F350 SRW CC
Project DUBBLUP
jdubb823 is offline
post #4 of 22 (permalink) Old 01-11-2013, 02:08 AM
7.3
7.3's Avatar
Re: Why not
its kinda un-needed in my opinion. but im never against mods lol
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #5 of 22 (permalink) Old 01-11-2013, 02:09 AM
7.3
7.3's Avatar
Re: Why not
what do you mean?
7.3 is offline
post #6 of 22 (permalink) Old 01-11-2013, 02:12 AM Thread Starter
jdubb823's Avatar
Re: Why not
Banks 6.0 compared to a banks 7.3?
Cooler egts is never a bad thing.
2002 F350 SRW CC
Project DUBBLUP
jdubb823 is offline
post #7 of 22 (permalink) Old 01-11-2013, 04:18 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Why not
No...
However your postings are confusing as all hell...
A stock 6.0 IC is no upgrade on a 7.3...
A larger then stock, like Spearco or DI, is just that, an aftermarket IC... There will be no differance between one made for a 6.0 or a 7.3...
Joe
CSIPSD is offline
post #8 of 22 (permalink) Old 01-11-2013, 04:23 AM Thread Starter
jdubb823's Avatar
Re: Why not
A stock 6.0 ic isn't better than a stock 7.3?
I was under the impression it was.
Under that impression I would also think a after market ic for a 6.0 would be better than a aftermarket 7.3.
Isn't the point of an after part to upgrade on a factory part?
2002 F350 SRW CC
Project DUBBLUP
jdubb823 is offline
post #9 of 22 (permalink) Old 01-11-2013, 04:30 AM
lincolnlocker's Avatar
Re: Why not
the way they are made may be the upgrade part... built better and stronger than stock but flow the same.
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100s,bdp live tunes,4''down 5''back,dieselsite adrenaline,diy RR w/walbro,bellowed uppies, BTS trans!
01, rclb, 4x4, zf6, caned ts tunes, xl work truck package, 4'' tbe
lincolnlocker is offline
post #10 of 22 (permalink) Old 01-11-2013, 04:31 AM
CSIPSD's Avatar
Re: Why not
The stock 6.0 IC has plastic end tanks, it is only marginally larger then the 7.3...
Most see no differance (as I did) or very little.
Once you go to an aftermarket IC, there is only so much room in the truck to make one, they are all pretty much the same size.
The best and largest IC on the market for our trucks is the hypermax unit, close second would be the Spearco, then the DI DIIC and out from there.
Joe
CSIPSD is offline
