Clutch & exhaust for Hauling truck : advice wanted - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-10-2013, 04:01 PM Thread Starter
What clutch to use for hauling with CNG fumigaiton?
I finally bought another 7.3, after my 99.5 was totaled in august.
it's an '02 250 4WD Crew and long bed with 127 km.
I'll be taking a 14,000 lb load of horses 3000 miles at the end of the month.
the exhaust manifolds are leaking. I've already ordered a 4" MBRP t409 exhaust. I will also be installing a Technocarb Compressed natural gas kit.(have a well and compressor, much cheaper than diesel)
I'm currently thinking of buying the Dorman Manifolds from Advance and the stock bolts from ford and stock up pipes and gaskets from ford.
I plan on pulling the trans to access the manifolds.
It makes sense to me to replace the clutch at this point.
should I go with the ford kit at $550 or
the advance auto Perfection kit $350
Or should I be upgrading in some way to handle the extra power (35-40HP?)
llopness is offline
post #2 of 9 (permalink) Old 01-10-2013, 04:10 PM
jaybuller's Avatar
Re: Clutch & exhaust for Hauling truck : advice wanted
i would go with a valair organic.... there around the same price if i remember and there able to handle 350rwhp... i had one in my 12v and it was butter smooth and never slipped even when towing heavy and that truck was built pretty good.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #3 of 9 (permalink) Old 01-10-2013, 04:18 PM
Village Idiot
southmike's Avatar
I have heard good things about valair and southbend.
much better then oem they both have different version depending on tq and hp range prob 3-900 including pressure plate alignment too etc.
though the 900 version is more for the 500plus crowd.
i would ask a few vendors like cary, dennis , bean etc..
all can get you a good clutch in the range your looking at i am sure.
southmike is offline
post #4 of 9 (permalink) Old 01-11-2013, 12:48 AM
I have a south bend dual friction plate (400hp) and would recommend it over the stock. I pull a 5th wheel and boat up and over the continental divide.
black_forest_f350 is offline
post #5 of 9 (permalink) Old 01-11-2013, 01:57 AM
Village Idiot
southmike's Avatar
what price range was that.
post #6 of 9 (permalink) Old 01-11-2013, 06:41 AM
Freak'n know it all
gottagofast's Avatar
I just put a southbend CON-OFE in my truck, single disk rated to 450 hp stated to be "moderate" engagement as in not as smooth as stock but not harsh like a racing/ pulling clutch $923 including a new flywheel
The CON-O rated for 350 hp would be more than enough for you and would be very smooth and about $200 cheaper
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #7 of 9 (permalink) Old 01-11-2013, 08:28 PM
I have a CON-O and it is very nice and smooth.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #8 of 9 (permalink) Old 01-15-2013, 12:12 AM
KB3MMX's Avatar
How much power is your CNG fumigation supposed to add?
With that in mind, I would spec a clutch with a minimum spec of at least 50+rwhp over what you plan to run the truck at. Extra clutch capacity is going to extend it's lifespan.
-08 F350 CC/SB
-S475 Billet turbo with .90AR housing @49PSI
-Elite custom aged Head studs
-Elite Valvetrain upgrade W/ Colt Cam (stage2)
-Black Maxx with MCC custom tuning
-SUNCOAST BILLET transmission W/ Precision TC
-Air Dog DF165
-Caltracs traction bars
-Detroit Locker
-Amsoil bumper to bumper
-BIG THANKS TO REIFF DIESEL!!
KB3MMX is offline
post #9 of 9 (permalink) Old 01-15-2013, 04:53 PM
machinestheman's Avatar
unless you find it nessecary for another reason the up pipes can be changes relatively easy from underneath the truck use pb blaster on those dang bolts every day for a week before you pull them theill come out nice and easy
also i would recommend getting soe bellowed up pipes and scrap the oem ones i got mine from ih and love them been leak free aswell as many others
also with weight like that take a minute or two and check your brakes well how well you go is nowhere as important as how well you stop
hope this helps good luck
machinestheman is offline
