Stock Turbo Upgrade Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-09-2013, 02:42 AM Thread Starter
AndrewjSmith
Ok I just watched an old Powerblock tv session they did for 7.3 stock turbos.
You use your stock turbo and basically build an improved stock turbo. New compressor housing, new turbine wheels ans waste gate?
the guy said a stock turbo will push 20 psi and this "upgraded" turbo will push 32 psi.
I can not find a part number to look up what it cost or do some research on the thing at all. Can anyone tell me if they have done this. And if its a good upgrade?
I have a 03 powerstroke. And am looking for something like this.
im confident I can switch out the parts just want to hear from someone that has done it how the truck run after!?
thanks in advance for the help!
also if anyone can help me with a model number from banks or a better company that puts out this package id appreciate it!
andrewjamessmith04 is offline
post #2 of 9 (permalink) Old 01-09-2013, 03:32 AM
jtgf250's Avatar
Re: Stock Turbo Upgrade Questions
Almost all the sites, Diesel Site, Beans, Ats, so on and so on, sell the parts. Ported shroud comp housing and wicked wheel, looking at $500-600 depending on where you buy the parts. Closer to the lower end. I'm pushing every bit of 25lbs on the stocker but more pressure isn't always good. It can still only flow a certain CFM. You have to remember pressure is a measurement of Resistance. Not air flow. Depends on what your needs/wants are on which way to go.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 9 (permalink) Old 01-09-2013, 04:01 AM
7.3
7.3's Avatar
get the new wicked wheel
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #4 of 9 (permalink) Old 01-09-2013, 01:43 PM
the stryker god
Waste of money, you can spend 800+ dollars to pimp out a stocker or spend 1300 on a 38r which actually is an upgrade.
bruce51d is offline
post #5 of 9 (permalink) Old 01-09-2013, 02:16 PM
X2....if you need more turbo-airflow get a 38r.
email:
Website:
OBSWIZ is offline
post #6 of 9 (permalink) Old 01-09-2013, 08:13 PM
Black 02's Avatar
Ryan
2002 Black F-350 4x4 Crew Cab LB Lariat
DP-Tuner F6, Irate T4, S468, T-500, 910's, AFE Intake, MBRP Stainless 4" Exhaust, Riffraff OCR, Casserly Stage II's, Riffraff FRx, Rebuilt 4R100 w/ Suncoast Triple Disc Converter, 6.0L Trans Cooler. 37x12.50R16.5 Super Swamper Trxus MT's w/ 6" Icon Lift. Locker Front & Rear w/ Heavy Duty Warn Hubs
Black 02 is offline
post #7 of 9 (permalink) Old 01-10-2013, 10:33 PM Thread Starter
AndrewjSmith
thanks guys im gonna get home from work and check out that 38r.
post #8 of 9 (permalink) Old 01-11-2013, 12:54 AM
jtgf250's Avatar
Thats why I stated what is your plan. Like said above you could spend almost the same money on the stock and get a 38r with about 30% more air flow.
jtgf250 is offline
post #9 of 9 (permalink) Old 01-11-2013, 01:56 AM
Village Idiot
southmike's Avatar
38r is more airflow and more sound...better for some others find the noise gets old towing etc..
some dont mind it either way.
but if your upgrades are very mild you wont gain anything major by the 38 and pimping the stocker isnt bad at all goal is very important.
but you can spend more on a stocker then a better turbo if you go all out.
ie 400 housing, 200 wheel, 400 up pipes, 400 intake, 200 waste gate controler, 150 spider with egr delete etc....now your in a range of a variety of far more suitable turbos.
if your goals are not bad i would wait for a 2nd generation wicked wheel and call it a day.
southmike is offline
