HPOP? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-06-2013, 09:41 PM Thread Starter
docweld's Avatar
HPOP?
Do I need or should I get the SPR1.1 or the Adrenaline HPOP for 250/200% sticks? the SPR 1.1 is almost $300 more.
As of right now:
2000 F-350 7.3 Dually
6 speed manual
4:10 rear
DIY intake
DIY 4" exhaust
Hypertech power programmer 3
I am looking into new parts now, Turbo,sticks,custom tunes and all other supporting mods needed starting with fuel.
docweld is offline
post #2 of 3 (permalink) Old 01-06-2013, 10:46 PM
the stryker god
Re: HPOP?
If you want to keep it at 450 use the stocker
bruce51d is offline
post #3 of 3 (permalink) Old 01-06-2013, 11:16 PM
OBS Stroker
Nodge's Avatar
Re: HPOP?
Get a scan gauge so you can monitor IPR duty cycle and hpop pressure.
You can make an educated decision from there, and you will have a very handy tool to help you monitor your engine.
I ran 238/100's on a stock 15* pump for quite awhile with good results.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
