to pull or not to pull? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-05-2013, 12:56 AM Thread Starter
Deciding on whether i should pull my motor, currently the turbo pedistol is leaking and just noticed that the oil cooler is starting to seep oil. I have to Drain the coolant to fix that.
I have studs and springs sitting on the bench waiting to go in the truck and was thinking What if i pull the motor and do everything at once. How hard are these things to pull? Motor has 232K on it right now. What else should i do while its out?
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, BTS
riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Hydra with GEARHEAD Tunes
lariat7.3 is offline
post #2 of 5 (permalink) Old 01-05-2013, 01:35 AM
docweld's Avatar
Re: to pull or not to pull?
I hear it is better and faster to just pull the cab off the truck. well if you have a lift. I am going to do new studs/springs and I was told to just pull the cab off and the motor is right there to work on.
As of right now:
2000 F-350 7.3 Dually
6 speed manual
4:10 rear
DIY intake
DIY 4" exhaust
Hypertech power programmer 3
I am looking into new parts now, Turbo,sticks,custom tunes and all other supporting mods needed starting with fuel.
docweld is offline
post #3 of 5 (permalink) Old 01-05-2013, 04:09 AM
19stroker97's Avatar
I see no reason to pull the motor. Yes, the studs, and springs would be much easier to replace, but in my eyes not worth the work to remove the engine for it. The turbo pedistal leaking is probably the ebv or the o-rings. It's not hard to replace. Should only take you a couple hours. The oil cooler may not need replaced, they tend to leak and you can just buy a gasket kit to fix that.
Studs: Head Stud Install - PowerStrokeNation : Ford Powerstroke Diesel Forum
7.3 head stud install step by step - PowerStrokeNation : Ford Powerstroke Diesel Forum
Oil cooler: 7.3 head stud install step by step - PowerStrokeNation : Ford Powerstroke Diesel Forum
Ford 7.3 Diesel Oil Cooler Repair Kit
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #4 of 5 (permalink) Old 01-05-2013, 06:18 AM
Binder man's Avatar
Few hours to pull the motor tops. Don't pull the cab. That's a 6L thing. You can do studs and springs with motor in though.
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #5 of 5 (permalink) Old 01-05-2013, 03:07 PM
Village Idiot
southmike's Avatar
joe probably had his motor pulled in the time it took to get to this thread...lol
turbo by the second post..........
If you want to clean, degrease , paint, or anything like that i would say pull it.
i would love to do that on my truck ..but also may get into wires..anytime i touch a connector on my truck it seems brittle and breaks half the time.
southmike is offline
