Quick drain for oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 01-03-2013, 11:26 PM Thread Starter
ajfetterman's Avatar
Quick drain for oil
I ordered a quick drain valve for the truck this morning, hoping they work as good as is advertised.
Now that the old girl is a DD I go through oil changes quite rapidly so I figured this would be a good purchase.
I bought the one with the nipple so I can run a tube through the hole on my oil catch can and not have to worry about babysitting it while it drains so it doesn't overflow.
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
ajfetterman is offline
post #2 of 37 (permalink) Old 01-04-2013, 03:27 AM
Terminator Nation
Re: Quick drain for oil
The Fumotos work great and you don't have to worry about wearing out the pan threads for the plug.
old man dave is offline
post #3 of 37 (permalink) Old 01-04-2013, 07:02 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
... Work great? If you mean slow as hell then sure.
Unless you change your oil when its hot, it takes FOREVER to get the oil out.
I find myself removing mine half the time anyway just because I get sick of waiting.
Joe
CSIPSD is offline
post #4 of 37 (permalink) Old 01-04-2013, 08:06 PM Thread Starter
Like 2 beers slow or 6 pack slow?
Sent from my iPhone using AutoGuide.com Free App
1988 Camaro Iroc Z
~Andy~
post #5 of 37 (permalink) Old 01-04-2013, 08:17 PM
Renegade Diesel
Renegade7.3's Avatar
I personally dont trust them enough to buy one. Id be pissed if while driving down one of the farm paths back to the wheels it gets hit just right and i dump oil all over the place in the middle of nowhere!
Diesel Tech in Ohio
E99 7.3L 6spd 4x4 Lariat
AFE 4" DP back straight pipe
Built in Kentucky!
340,000 miles
"wear your high mileage as a badge of honor"
Originally Posted by dieselboy01 View Post
its a 7.3 thing, you wouldn't understand.
Renegade7.3 is offline
post #6 of 37 (permalink) Old 01-04-2013, 08:27 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
i still have one and i liked it but its been on the shelf for quite a while now..i see too many threads when some one finds nuts, bolts or cooling jets when they dump there oil....thats something you wont find using the drain valve..
Ron's power stroke is offline
post #7 of 37 (permalink) Old 01-04-2013, 08:53 PM
Administrator
Zmann's Avatar
Those aren't for Me either
who can't muster removing a bolt ?
I have never worn out threads in a oil pan
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 37 (permalink) Old 01-04-2013, 09:17 PM Thread Starter
Feeling real good about my purchase now.
I'm going to try it out, it was only $30 shipped so what the heck. I don't mind if it drains slow, I usually do other things while I'm changing my oil anyhow.
If a bolt comes out of my oil pan when I drain the oil I have way worse problems.
1988 Camaro Iroc Z
~Andy~
post #9 of 37 (permalink) Old 01-04-2013, 09:22 PM
Administrator
Zmann's Avatar
sorry about that
I pull up a 5 gallon bucket pull the plug and do other things also plus the drain lug has a inspection magnet so at least clip one on the pan it might cattch the junk if any and unclip it when u drain the oil to flush the fines
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 37 (permalink) Old 01-04-2013, 09:35 PM
CSIPSD's Avatar
I bought two... My wife took one look at it and said "Not on my truck"...
I always hit the bottom of the pan with a deadblow hammer to make sure. Only had something knock back once...
Joe
CSIPSD is offline
