shifts hard after new tunes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-03-2013, 04:09 PM Thread Starter
richh789's Avatar
Before Xmas I had stage 1 swamps injectors put in. (Which work great) now when ever I'm in it a bit, if it shifts above 2500 Rpms, it feels like the power plateus for a brief moment then, bang into the next gear.
Shifts smooth as can be under 2500. Tunes are from swamps, my last set of tunes was from php.
Any ideas?
I do a lot of highway driving so it isn't really a big deal for now, but would like to get it resolved so I don't brake something if I forget to ease into the throttle
00 F350 cclb former dually
1"shackles, 6" lift, 37" oz, HD headlights, AFE intake, bellowed up pipes,swamps stage 1s, swamps tunes, 5" exhaust, iah, ebpv, foil all deleted,zoodad, pillar guages; boost, Pyro, fuel pressure. MBC,
97 ex cab PS SOLD
04 CCLB 6.0 EDGE J W/A, 4"mbrp Sold
93 idi sold
richh789 is offline
post #2 of 15 (permalink) Old 01-03-2013, 04:15 PM
IIvonnyII's Avatar
Re: shifts hard after new tunes?
The faster trannys shift gears, the more they like it. If its just a fast hard shift.. I wouldn't be too worried . If it seems to hesitate to shift and then bangs into gear.. I wouldn't want to run those tunes. Just my opinion
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #3 of 15 (permalink) Old 01-03-2013, 07:55 PM
7.3
7.3's Avatar
maybe try a bts valve body
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #4 of 15 (permalink) Old 01-03-2013, 07:56 PM
Old Yeller, REBORN
kilapapipa's Avatar
Put an upgraded valve body in it. BTS or JW. Really makes a difference.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #5 of 15 (permalink) Old 01-03-2013, 08:13 PM Thread Starter
richh789's Avatar
Pan gasket needs to be changed, pardon my lack of trans knowledge, is valve body accessible with pan off? Straight forward change?
I ended up getting a new ts chip ( diesel shop said php tunes are burned on a different format) I had contemplated sending that one back to k&t to have tunes burned for the single shot stage ones.
97 ex cab PS SOLD
93 idi sold
richh789 is offline
post #6 of 15 (permalink) Old 01-03-2013, 08:17 PM
Old Yeller, REBORN
kilapapipa's Avatar
Yes, drain pan, remove pan, remove filter, remove VB, and reverse it. instructions will have torque specs for you.
post #7 of 15 (permalink) Old 01-03-2013, 08:18 PM
Did you happen to contact your tuner about this first?
countryboyrob is offline
post #8 of 15 (permalink) Old 01-03-2013, 08:39 PM Thread Starter
richh789's Avatar
Called tuner yesterday, left msg today too. Wasn't sure if they were closed a few days for the holidays. Was kinda antsy so I posted here. I just wanted to try to be informed when I talk to him.
Was just reading on swamps site that their tunes have added line pressure. They say if it shifts to hard they can burn without added lp. Don't really have any experience with this. Wasn't sure if it was just a coincidence, and something in trans is going. Odd how it only happens above 2500d
97 ex cab PS SOLD
93 idi sold
richh789 is offline
post #9 of 15 (permalink) Old 01-03-2013, 08:43 PM
Because thats when the tunes are calling for more line pressure ....
post #10 of 15 (permalink) Old 01-03-2013, 09:50 PM
dkrajcovic
http://brianstruckshop.com/docs/BTS%...stallation.pdf
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
