Lowering Compression - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-27-2008, 03:11 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
For those that have lowerd comp. how low did you go or how low can you go and keep it streetable and start without either?
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 11 (permalink) Old 08-27-2008, 04:07 AM
Re: Lowering Compression
i had the bowls machined out using Charles' method. He can explain better than I can, im sure he'll be around tomorrow and share the details.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #3 of 11 (permalink) Old 08-27-2008, 04:54 AM
Plays with Motors
Machinist's Avatar
Here's how it's done by changing the piston bowl. The center was re-shaped while maintaining swirl direction, the edge of the bowl was layed back to discourage cracking.
http://s287.photobucket.com/albums/l...oke%20pistons/
Final compression will be around 16:1
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #4 of 11 (permalink) Old 08-27-2008, 05:06 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Ok thanks about how much was removed from the bowl area? We do the same on the pistons in the tractor but that is much lower comp. in that.
Tow Mule
post #5 of 11 (permalink) Old 08-27-2008, 06:51 AM
Plays with Motors
Machinist's Avatar
I would have to look at my paperwork, but I think it was 7cc increase.
2011 335i M-Sport
post #6 of 11 (permalink) Old 08-28-2008, 12:44 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Ok thanks for the info. If you find out for sure let me know please, pm me or whatever you want to do.
Tow Mule
post #7 of 11 (permalink) Old 08-28-2008, 07:59 PM
Ricky Bobby
JSlack's Avatar
what are you runnin for machine there Machinist? looks to be a Haas by the looks of it...
Im runnin a VF-3 and VM-6 here at work. Vaccum Form mold work...
JSlack is offline
post #8 of 11 (permalink) Old 08-28-2008, 11:00 PM
mine look just like machinist's pistons. iirc mine are at 16:1 compression aswell.
2013 ccsb 4x4-stock
post #9 of 11 (permalink) Old 08-29-2008, 01:14 AM
Plays with Motors
Machinist's Avatar
2) HAAS VF-3 HSS's with through spindle coolant
1) HAAS VF-2 HSS
1) Hwacheon HP-200A CNC Lathe
Couple of EDM's and a whole bunch of manual machines.
2011 335i M-Sport
post #10 of 11 (permalink) Old 08-29-2008, 01:16 AM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Those look nice! good Work! 15.5:1-16:1 is a good place to be!
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
