Water meth systems? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-30-2012, 07:36 PM Thread Starter
7.3_geek_124's Avatar
Water meth systems?
I have been looking at a water methanol injection system for my 2001 f-250, and i noticed that snow makes many different kinds but each kit has the same exact components in the kit? the only difference is the analog gauge that comes with it. I'm looking for better performance and possibly better mpg's but not sure what kit to run. Anyone have more experience with the kits and did you see a noticeable change in the performance of the truck?
7.3_geek_124 is offline
post #2 of 6 (permalink) Old 12-31-2012, 04:03 AM
tree trimmer's Avatar
Re: Water meth systems?
if your looking at a water kit for power, mpg's, or performance, look elsewhere as you will have a failure somewhere, some time.
water kits should be used for control of egt's, not for power.
there are several of us with them, and a few of us had failures related to water/meth when attempting to use for power.
add bigger injectors, and use it for control of egt's.
and a coolingmist kit is what your after.
2010 f350 srw lariat
tree trimmer is offline
post #3 of 6 (permalink) Old 12-31-2012, 06:31 AM Thread Starter
o alright, yea because i purchasing bigger injectors, and turbo, and a fuel system but i dont want to overdue it with those pmr's i have in that truck. just trying to find the best combo for a strong but quick truck.
post #4 of 6 (permalink) Old 12-31-2012, 11:04 PM
Old Yeller, REBORN
kilapapipa's Avatar
Good advice here.
Tree Trimmer, I was just asking about you recently. Looks like your just in the 6.4 section now. I missed your avatar, .
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #5 of 6 (permalink) Old 12-31-2012, 11:52 PM
tbolt's Avatar
cooling mist for egt's only is my advice.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 6 (permalink) Old 01-01-2013, 02:03 AM
Originally Posted by kilapapipa View Post
Good advice here.
ya, with the way corn is now, i bought a newer one.
should be able to get it payed for before the floor falls back out of corn, hopefully.
if it just didn't need to be at empire, for some.....things, i'd probably have it about half payed off.
corn was good to me this year.
but dont worry, i still come back and visit.
