DP-TUNER in and just cranks. Reflash?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-29-2012, 11:12 PM Thread Starter
I bought an F6 from my buddy out of his 2001 7.3. I just put it in my 02 and it just cranks over and over. The glow plug light won't turn off either. And chevk engine is on. The controller lights up and it works normal. So i pulled the chip out and it fires rite up. I don't have a problem on my 96 with changing dp to another truck. Does the F6 have a vin lock?
1996 F-250 4x4
BD Diesel Thruster II Turbo, DP-Tuner 120hp Race,
Snow Performance Stage 3 Mileage max, strate 5" into 6inch stacks, Swamps 175/30% injectors,
Built E4OD, Banks techni-cooler, Tymar intake, 4 inch lift on 35's, HID headlight conversion 300,000 miles
THUNDERstroke73 is offline
post #2 of 11 (permalink) Old 12-29-2012, 11:19 PM
the stryker god
Re: DP-TUNER in and just cranks. Reflash??
Go back and clean the contacts again
bruce51d is offline
post #3 of 11 (permalink) Old 12-29-2012, 11:46 PM
01 and 02 do not use the same default hex code, it might run but will set a CEL
sootmonster is offline
post #4 of 11 (permalink) Old 12-29-2012, 11:57 PM
SeeYa's Avatar
Double check the cable ends are installed per our instructions. If your buddy didn't give them to you they can be found under our knowledge base online. However, if you want your truck to run like it should you need new tunes for the 2002 because of the differences in PCM family codes.
All you need to do is go to our site, register and create a helpdesk ticket. We need to to register the F6 to you so we will need to know who you bought it from and get your PCM code for new tunes. Charges to do this can also be found under our knowledge base.
*If I had to guess you have a California coded PCM.
Let us know if we can doing anything else for you.
Diane
SeeYa is offline
post #5 of 11 (permalink) Old 01-01-2013, 07:33 PM
dkrajcovic
X2
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
post #6 of 11 (permalink) Old 01-13-2013, 10:07 PM Thread Starter
Still have issues. I got new tunes from DP (thank you Diane) and i cleaned the computer 3 times. The truck starts but idles ruff and is missing. Puffs black out too. I've done 3 of these chips and never beem so confused. Still has the check engine light on and wait to start never goes off. Any suggestions will be appreciated!!!
1996 F-250 4x4
post #7 of 11 (permalink) Old 01-13-2013, 10:20 PM
SeeYa's Avatar
Confused for sure. We have many people running the same set up as you with our tuning.
Did you double check the PCM code again for us before getting new tunes? The WTS not going off really sounds like the tunes are not for the right PCM code.
Email me your name and contact number. We will get to this straightned out. [email protected]
Thanks
Diane
SeeYa is offline
post #8 of 11 (permalink) Old 01-15-2013, 12:48 AM
Village Idiot
southmike's Avatar
didn't clean too much did you...
see if the numbers are on the pcm itself to verify codes..some people swap them.
i know i run a pmt instead of an exl on mine for example.
sounds like your in good hands though.. cant beat an f6 for uploading.
southmike is offline
post #9 of 11 (permalink) Old 01-27-2013, 05:42 PM Thread Starter
Sent chip and pcm back to Jody. Worked his magic and now everything is in and works great. Another happy 7.3 in the books
1996 F-250 4x4
post #10 of 11 (permalink) Old 01-27-2013, 09:47 PM
Village Idiot
southmike's Avatar
Nice...that will do it for sure.
Bet it is a whole new truck now.
