Scan gauge? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 41 (permalink) Old 12-28-2012, 06:04 AM Thread Starter
kupaa's Avatar
Scan gauge?
Does any one know if the scan gauge will monitor water temp?
02 F-250 SC SB 4X4
AUTOMETER COBALT EGT BOOST TRANS
4'' SILVERLINE TURBO-BACK STRAIGHT PIPE
6637 INTAKE
HP CROSSOVER LINE
DP TUNER LIVED TUNED BY JODY
JOHN WOOD STREET PERFORMANCE TRANS
CASSERLY 200CC 80% HYBRIDS
TERMINATOR MODDED HPOP
ITP REGULATED RETURN
GARRETT GTP38R
ITP OVERBOOST ANNIHILATOR
468HP 970TQ
CHRIS
kupaa is offline
post #2 of 41 (permalink) Old 12-28-2012, 07:20 AM
Re: Scan gauge?
The 7.3L PCM does not monitor coolant temperature, it measures oil temperature.
You can add an aftermarket temperature sensor if you feel the need to though.
post #3 of 41 (permalink) Old 12-28-2012, 07:22 AM Thread Starter
kupaa's Avatar
Re: Scan gauge?
Is water temp not important? I know oil temp is but how do I know if it's running hot?
02 F-250 SC SB 4X4
6637 INTAKE
HP CROSSOVER LINE
GARRETT GTP38R
468HP 970TQ
CHRIS
kupaa is offline
post #4 of 41 (permalink) Old 12-28-2012, 12:57 PM
Re: Scan gauge?
An Aeroforce scangauge will read coolant temp..... It reads it on my 02.
countryboyrob is offline
post #5 of 41 (permalink) Old 12-28-2012, 01:57 PM Thread Starter
kupaa's Avatar
Re: Scan gauge?
Ok thanks I might have to buy one now.
02 F-250 SC SB 4X4
6637 INTAKE
HP CROSSOVER LINE
GARRETT GTP38R
468HP 970TQ
CHRIS
kupaa is offline
post #6 of 41 (permalink) Old 12-28-2012, 06:13 PM
Re: Scan gauge?
Is it accurate? I know the 7.3L has an ECT sensor, but I thought it was just used for the dash gauge and I have heard it is extremely inaccurate when monitoring it.
Also, is your 2002 a manual?
post #7 of 41 (permalink) Old 12-28-2012, 06:14 PM
Re: Scan gauge?
Water temp is not near as important as oil temp. You can tell if it is running hot by watching oil temperature.
post #8 of 41 (permalink) Old 12-28-2012, 07:46 PM
Re: Scan gauge?
Its an auto.
And yes I would say its accurate, temp reading does climb up then the t-stat opens and temps drops down around 190-195*. Stays there while driving normal and if I hot rod it around town or towing the temp does go up.
post #9 of 41 (permalink) Old 12-29-2012, 01:40 AM
SeeYa's Avatar
Re: Scan gauge?
Where's the gong smilie when you need one?
There is nothing in 7.3l PCM to display ECT. The sensor is only for the dash reading. This must be done with a mechanical gauge to get an accurate ECT reading.
SeeYa is offline
post #10 of 41 (permalink) Old 12-29-2012, 02:20 AM
Re: Scan gauge?
Then please tell me why it displays coolant temp.....
