Switch mounting idea - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 12-24-2012, 03:48 PM Thread Starter
So i had an idea for mounting switches...get one of these ( Autometer Image ) and plug up the holes with these ( http://www.dieselmanor.com/isspro/R7614.asp ) and drill into them to mount my ebpv switch, and my chip switch when I get it and possibly a gauge in the last hole. Or do you think i should just man up and drill into the dash for the switches and forget the stupid under dash custom gauge idea? Thoughts/ideas/pictures welcome!
03machstock is offline
post #2 of 22 (permalink) Old 12-24-2012, 04:55 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Switch mounting idea
its a good idea but what ever floats your boat...its your truck.. i have switches in the lower panel under the steering wheel.. if i sell the truck..ill just pick up a new panel if i need to
2
Ron's power stroke is offline
post #3 of 22 (permalink) Old 12-24-2012, 06:18 PM
Eng53ine's Avatar
Stock 02 F-250 7.3, auto, 4x4, CCSB, Lariat, 4" duals, 6637, zoo dad mod, 6 pos ts, mile marker lock outs
Eng53ine is offline
post #4 of 22 (permalink) Old 12-25-2012, 12:37 AM
Village Idiot
southmike's Avatar
I have seen a pic of a ts switch and one toggle mounted in the lower cheek of a pillar that looked good. I just mounted mine in a blank spot on the dash to the right of my 4x4 switch..
I think that is either adjustable pedals or air. Ag disarm switch depending on model..
southmike is offline
post #5 of 22 (permalink) Old 12-25-2012, 12:43 AM
I opted to do the F650 dash (the automatic version) for mounting my switches. I polished up a stainless steel plate and put it over the large opening, and have switches mounted there. I have my tuner mounted in the recessed area to the left of the switches. If you're interested, i'll attempt to take a decent picture of the setup. All that being said, its pretty much just a home made knock off of the the one from riff raff.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
4" exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #6 of 22 (permalink) Old 12-25-2012, 02:24 PM Thread Starter
Yea if you dont mind, im always interested in peoples set ups!
e99 F-250 Reg. cab lariat 4x4 man transfer case, 6 speed 7.3
Isspro ev2 Boost, Pyro
6637
MBRP 4" with muffler
Rigid d2's
post #7 of 22 (permalink) Old 12-26-2012, 01:57 PM
Coal Train Diesel
ventryjr's Avatar
Where do you get the f650 dash? And have any pics? Thanks.
01 f350 dually CCLB, 7in lift, 6637 zoodad, 4.5" stacks, Isspro gauges, PHP Hyrda, ww2, industrial injectors 180/40
ventryjr is offline
post #8 of 22 (permalink) Old 12-29-2012, 05:27 PM
I know the switches don't match right now, and that is due to me being busy/lazy. Once I finish my driving lights and fog lights I'll have everything wired to Carling switches. It also does not bother me that i have tan interior and the dash is grey.
If you have someone using the center front seat often, you might want to go with the manual version rather than the auto version. It does stick out a good amount....and leads to people hitting their shins on the dash panel. However, if you dont have anyone in that seat very often....the auto is a great choice. The switches are very easy to reach and very easy to see while you're driving.
The final thing is, I'm pretty sure that i got it from Stealth Diesel (I really don't remember though).
4" exhaust
post #9 of 22 (permalink) Old 01-01-2013, 02:44 PM
NEVRNF's Avatar
Here is what i did as i dont like cutting holes in panels.
[IMG][/IMG]
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #10 of 22 (permalink) Old 01-01-2013, 07:35 PM Thread Starter
[IMG][/IMG]
That is awesome
6637
Rigid d2's
