boost gage sensor location - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-23-2012, 10:30 PM Thread Starter
Biscayne's Avatar
So...I am researching gages and see that there are two different ways to install the boost sensor. One way is on a T to the MAP line and one has you tap it into the piping near the turbo. Pros and Cons for both ways? I am sure the easier way has a disadvantage but does it out weigh the ease of install? Opinions are welcomed. My truck is a 2000 F350 crew cab in my sig. I am leaning towards some ISSPRO gages but haven't pulled the trigger yet.
_____________________________________________
2000 F350 CCSB 7.3 liter 4x4 mods- GP relay / PHP 6 pos / 6637 int / hutch / harpoon
2001 F250 ECSB 4x4 - sold
2001 F250 CCSB 2WD -sold
2002 F250 ECSB 4x4 lifted -sold
Mama's 2009 Expedition EL 4x4
Biscayne is offline
post #2 of 7 (permalink) Old 12-23-2012, 10:45 PM
Gun Clinger
Re: boost gage sensor location
Easiest way is to delete the AIH and get the tapped plug for a gauge.
2002 XLT 4X4 EX - Bone stock for now...
jason812 is offline
post #3 of 7 (permalink) Old 12-24-2012, 01:25 AM
dkrajcovic
do a AIH delete with a tapped plug for a gauge
that is what i did
Riffraff Diesel: RDP AIH Tapped Fitting
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
post #4 of 7 (permalink) Old 12-24-2012, 01:29 AM
theoldgirl1990's Avatar
I just installed the AIH plug for the boost gauge on my dads 2001. Works very well and the gauge is really smooth and accurate.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #5 of 7 (permalink) Old 12-24-2012, 02:20 AM
OBS Stroker
Nodge's Avatar
Can't go wrong with isspro.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #6 of 7 (permalink) Old 12-25-2012, 02:35 AM
Village Idiot
southmike's Avatar
Easiest could be ordering a pre threaded aih delete bolt.
That may be hard to do on an early 1999 though... Lol
southmike is offline
post #7 of 7 (permalink) Old 12-26-2012, 01:54 AM
I would go with the AIH delete with the boost tap. I did the MAP location and it resulted in a rattling boost gauge. I did the AIH version and it is smooth as silk.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
