Good set up or no? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-17-2012, 05:33 PM Thread Starter
MattFoster55's Avatar
Good set up or no?
i have a 2000 7.3 and have a 5' turbo back exhaust gagues tony wildman chip,but want some more hp. I'm looking into the Garrett gtp 38R turbo 250cc/30% injectors a fass fuell system and a stage 2 cold air intake figure it would make it around 400+ hp any ideas on how good the setup is and if i should add anything to it
2006 F350 ext cab long bed 6 spd.starting all over on her.general grabber A/T 2 powermax,egr delete,gaskets,sct,mbrp 4" straight pipe exhaust,blue spring kit,glow shift gauges,sinister coolant filtration kit.
MattFoster55 is offline
post #2 of 7 (permalink) Old 12-17-2012, 05:38 PM
the stryker god
Re: Good set up or no?
160/80, 38r, regulated return, 6637. Save some money
bruce51d is offline
post #3 of 7 (permalink) Old 12-17-2012, 08:25 PM
OSCS's Avatar
Id Scrap the fass fuel system and get some 200/80's. should make some good power.
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #4 of 7 (permalink) Old 12-17-2012, 08:58 PM
co04cobra's Avatar
Ditch the fass. 238/80s or 238s/100s. Your stock fuel will probably be fine if you only want 400hp. If you want to upgrade fuel look at sinisters kits, DIs, or beans. They all have a nice setup.
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #5 of 7 (permalink) Old 12-17-2012, 10:00 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
If you're looking for 400hp, do a set of stage two's, 160/80s or small hybrids 200/30 I think the 200's would suit you better.
Stock
PowerstrokeJunkie is offline
post #6 of 7 (permalink) Old 12-17-2012, 10:20 PM
Dustin F2504x4's Avatar
The 200/30 injector is a good for a street truck. Run cool egts with 38r on my truck
Sent from my iPhone using AutoGuide.com Free App
2001 Ford f250 Power Stroke 4x4
Dustin F2504x4 is offline
post #7 of 7 (permalink) Old 12-18-2012, 12:00 AM
Village Idiot
southmike's Avatar
i hope that was a five inch system....lol
250/30 would be a terrible injector...250/100 or 250/200 or 200/30 would be better...but overkill for 400.
fass fuell systems look great on paper..the pump burns up way too quick.
a few airdog 2 have as well. if you want a water/ air removal i would do the air dog 150, if you want a better fuel system i would get something like DI , irate , martys diesel reg return or fuel system. possibly dual stockers.
and do tank mods ie..new pickup and pre pump filter.
the afe2 stage 2 is goo intake , a lot sharper looking then a moddified napa 6637...but a lot more coin.
southmike is offline
