24 volt Offroad Lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-13-2012, 01:30 AM Thread Starter
I have 3 7" 10-LED TruckLite Off Road lights (military grade) that are wired for 24 volts. i was thinking of tapping power from a hot wire, to a toggle switch on the dash, then to a 12v to 24v step up converter, the onto the lights. from there, i'm stumped. do i then just run to ground?
Also, each light only draws 1.5 amps.
Here's the lights i'm working with:
More info on product here: http://www.truck-lite.com/webapp/wcs...8629&langId=-1
Cowboy up and party down!!!
1999 SuperCab F250 PSD, 4x4 6spd
Redneck_Medic is offline
post #2 of 12 (permalink) Old 12-13-2012, 01:52 AM
JSchuricht's Avatar
Re: 24 volt Offroad Lights
1.5a at 24v is 3a at 12v
Run your +12v to a 10a fuse
Fused +12v to a switch that can handle 7.5a or more
+12v from the switch to the + side of the step up converter input
- side of the step up converter connects to vehicle ground
Run a wire from both the + and - side of the step up converter output to the lights
Connect all light + wires together, all light - wires connect together
JSchuricht is offline
post #3 of 12 (permalink) Old 12-13-2012, 01:56 AM Thread Starter
awesome, thanks!
post #4 of 12 (permalink) Old 12-13-2012, 02:03 AM Thread Starter
What gauge wiring should be sufficient?
post #5 of 12 (permalink) Old 12-13-2012, 02:05 AM
JSchuricht's Avatar
Depends on the distance but 14ga should be perfect.
post #6 of 12 (permalink) Old 12-13-2012, 02:06 AM Thread Starter
sweet. thanks again. i'll post pics once all set up
post #7 of 12 (permalink) Old 12-13-2012, 02:09 AM Thread Starter
Just to clarify, where does the (-) side of the switch connect to?
post #8 of 12 (permalink) Old 12-13-2012, 02:37 AM
19stroker97's Avatar
Anywhere you can get a good ground. Bare metal.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #9 of 12 (permalink) Old 12-13-2012, 02:57 AM
you dont switch anything thats on the ground or (-) side. only positive is switched.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #10 of 12 (permalink) Old 12-13-2012, 10:55 PM
JSchuricht's Avatar
Actually you can switch the ground side if you wanted. I am guessing that the switch you have is backlit so you have a +12v, switched and a - contact on the switch. Just hook + to + and - to ground, switched to the converter and you will be good.
