Whitch belt is best? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-11-2012, 10:29 PM Thread Starter
Bobs 7.3
Bobs 7.3's Avatar
Im changing my serpentine belt tensioner with the one from motorcraft as its chirping with 173,000 miles on it and wondering what belt is the best for replacement? Ive used the gator back with ####ty results. Is the motorcraft the best or is there a better aftermarket belt I can get?
Bobs 7.3 is offline
post #2 of 5 (permalink) Old 12-11-2012, 11:12 PM
Treyspooner65's Avatar
Re: Whitch belt is best?
Stick to motorcraft. 173,000 is good life, and no gambles on quality.
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), AIS Intake, RR-IC Boots, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, 05+ Tow mirrors, Custom Flag Mount
Treyspooner65 is offline
post #3 of 5 (permalink) Old 12-12-2012, 12:02 AM
dkrajcovic
OEM motorcraft is the only way to go
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
post #4 of 5 (permalink) Old 12-12-2012, 02:08 AM
If you have the upper radiator hose which runs through the center of the belt, you can replace it with one which I believe goes on the engine for dual alternators. This moves it to the outside of the belt allowing you to change the belt with out dropping coolant out.
'01 F250 4x4. 6 spd. GTP38R, Bellowed up pipes, tymar, straight piped, boost & EGT guages.
jopes is offline
post #5 of 5 (permalink) Old 12-12-2012, 02:53 AM Thread Starter
Bobs 7.3
Bobs 7.3's Avatar
Thanks guys that motorcraft seems the way to go and jopes Im lucky mine runs on the outside of the radiator hose and thank you for reminding me about that. I actuclly went and double checked. I was gonna stick with motorcraft and tried the gator back 3 years ago but man it chirped since day one I put it on so new tensioner set up and belt all from motorcraft seems the only way. thanks again
Bobs 7.3 is offline
