2000 f250 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-11-2012, 12:44 AM Thread Starter
strokin'
dirtyD's Avatar
2000 f250 7.3
i have a 6 speed manual trans is there any remote starts out there for a manual trans
dirtyD is offline
post #2 of 6 (permalink) Old 12-11-2012, 01:39 AM
Village Idiot
southmike's Avatar
Re: 2000 f250 7.3
Should be.. but you will need it time be in neutral w parking brake on etc...
No reason it should work otherwise. I don't recall the one one I put non looking for anything special other then a delay for glow plugs or wts light. Just remember if it is in gear and you crank it she will move.
southmike is offline
post #3 of 6 (permalink) Old 12-11-2012, 09:16 PM
Livin in the flatlands.
Cutty72's Avatar
Re: 2000 f250 7.3
I know both AstroStart and AutoStart work with a manual. Just need a little different programming, and a Ebrake switch.
'01 F250 CCSB
6637 Intake, 38R, 4" MBRP TB w/muffler
Tunes by SWAMPS
Goodyear DuraTrac 285/75 R16
ND Command Supply Services branch officer
Cutty72 is offline
post #4 of 6 (permalink) Old 12-12-2012, 01:47 AM Thread Starter
strokin'
dirtyD's Avatar
Re: 2000 f250 7.3
E brake switch and thanks for the replies
dirtyD is offline
post #5 of 6 (permalink) Old 12-12-2012, 08:56 AM
jtgf250's Avatar
Re: 2000 f250 7.3
Yeah only big differance is time delay relay and you have to bypass the clutch switch. But definitly remember to leave it in N and brake on. Watched a guy I know start his and forgot he had left his in first, ran right up on the hood of another guys car we knew. Funny but bad news.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #6 of 6 (permalink) Old 12-12-2012, 04:17 PM
Re: 2000 f250 7.3
I had an Astrostart on my previous truck. It used this procedure to make sure it was left out of gear:
1. Engine running, set park brake
2. Tap brake
3. Turn key off (engine continues to run)
4. Exit vehicle
5. Engine shuts off when door closes.
If a door gets reopened, the remote start is disabled. This was kind of a pain sometimes. If you ran back out to grab something out of the truck, you had to restart the truck or it wouldn't remote start the next time you needed it. Slightly inconvenient but was nice if you remembered to "arm" it.
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
