If I have to rebuild... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 09-12-2007, 04:04 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Sponsers help me out here, what am I looking at for...
1. .30 over pistons
2. full rebuild kit
3. what ever else I might need
4. Stud it while its out???
I am really hopeing its just a IPR or HPOP system issue but...
Joe
CSIPSD is offline
post #2 of 26 (permalink) Old 09-12-2007, 04:24 PM
Re: If I have to rebuild...
If the block is OK, and none of the rods are bent, then a Ford rebuild kit should do the trick. Slap in some H11's and call it good. Just need to know what your future mod plans are.
bbunting is offline
post #3 of 26 (permalink) Old 09-12-2007, 04:37 PM Thread Starter
CSIPSD's Avatar
Really its a DD that will see some sled pulls and such... Its done great for me up tell now, I might be jumping the gun so to speak, as the dealer has not even got it in yet.
But 400-450hp, No spray, water/meth... If it needs rebuild I will step up to dual oil maybe a TN T-60 series...
Joe
CSIPSD is offline
post #4 of 26 (permalink) Old 09-12-2007, 04:41 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: If I have to rebuild...
Hey, Just you keep your panty hose on Mr. Wait till the tec gets his hands on it, I'd put money on it being something stupid. I hope you did'nt melt a piston though, sounds like a injector issue more than anything.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #5 of 26 (permalink) Old 09-12-2007, 04:48 PM
skylinedan's Avatar
What the, you take your lap top evrywhere you go or what? First your on the side of the road and posting , now your at the stealer ship. . I did read the other post on whart happened, You think it got hot enough to melt the piston?
post #6 of 26 (permalink) Old 09-12-2007, 04:49 PM Thread Starter
CSIPSD's Avatar
I dont know right now... I am at work... But I am betting its a IPR or something like that, but 1 gallon of diesel fuel in the oil did nothing any good...
Joe
CSIPSD is offline
post #7 of 26 (permalink) Old 09-12-2007, 04:53 PM
skylinedan's Avatar
Unhappy Re: If I have to rebuild...
Well look on the bright side if the motor turns out to be ok , It will be one of the cleanest on the face of the planet. Keep us in the skinny though.
Dan
post #8 of 26 (permalink) Old 09-12-2007, 04:57 PM Thread Starter
CSIPSD's Avatar
I will... Just tired of driving a F150 from hertz and its got a FRICKIN BACKUP ALARM...
Joe
CSIPSD is offline
post #9 of 26 (permalink) Old 09-12-2007, 04:58 PM
LMAO, what will you do for rods, if it needs a rebuild?
When/If I pull my engine, I plan on:
Forged Rods (flux'd, shotpeen'd)
H11's
Comp Valve Springs
Stock HG's
Rebuild kit with new pistons, etc
gregrob is offline
post #10 of 26 (permalink) Old 09-12-2007, 05:03 PM Thread Starter
CSIPSD's Avatar
Just Forged Rods... I'm not looking to compete with the big dogs... 400-450 is fine for me.
Joe
CSIPSD is offline
