ww vs gen 2 ww vs van turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-08-2012, 01:53 PM Thread Starter
So i was doing a little research and came across some info that got me thinking. I knowbthe original ww is used for surge issues. But this new gen 2 ww appears to outflow a stock turbo and give surge relief.
So here is my question...some people say a van turbo is an ok upgrade and a 38r is lots better. Where does this new gen 2 fall in this scale? I cant seem to find much info.on it. Anyone have any insight? Numbers would be good or an explaination as to why the gen 2 falls where itbdoes. I'm assuming it would go like this.
Gen 1 WW
Stock turbo
Van turbo and Gen 2 equal to one another
38R
T4 setup
Etc
99 F350 (99.5 motor E99 suspension)
Rebuilt tranny (with shift kit) @ 114,000
6637, Foil Delete, IC tubes Boots and clamps cleaned
kenmore is offline
post #2 of 9 (permalink) Old 12-08-2012, 02:47 PM Thread Starter
Re: ww vs gen 2 ww vs van turbo
Yes i realize this is a new product and its not in full time production yet. But any info as to how they all compare right now would be nice. Even if its cfm, static pressure and x psi at y rpms would be helpful. I will research and.post once i can put together a decent comparison list with specs
kenmore is offline
post #3 of 9 (permalink) Old 12-08-2012, 03:10 PM
International Diesel Tech
purplepstroke's Avatar
PHP is the first person to try one out. Other then that they are going to have some guys start testing them so no one owns one yet.
E99 7.3***230/100 PIS sticks***swamps tuning*** 4" mbrp***t500 HPOP***6637 filter***BTS valve body***racerx torque convertor***di reg return***walbro fuel pump***20x10 fuel hostages with Nitto 305 terra grapplers
purplepstroke is offline
post #4 of 9 (permalink) Old 09-25-2013, 04:34 PM Thread Starter
Bump
kenmore is offline
post #5 of 9 (permalink) Old 09-25-2013, 04:41 PM
jaybuller's Avatar
I would say a stock sd turbo with ww2 and a 1.0 ex housing, high flow outlet and a turbo master would be just one sep under a 38r, I don't like van turbo do to lack of waste gate and the 1.15 is to big for my 6 speed truck, might be okay on an automatic though?
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #6 of 9 (permalink) Old 09-25-2013, 06:11 PM
old Smokey's Avatar
Still lagy on an automatic. I have the ww2 with van turbo. It is best at 3200 rpms just not in the low rpms.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #7 of 9 (permalink) Old 09-25-2013, 09:24 PM
Currently running a ww2 on a van turbo. With 160/30 injectors it spools just slightly slower than everything stock.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #8 of 9 (permalink) Old 09-25-2013, 11:14 PM
jaybuller's Avatar
Your running the same setup as me, except I'm running the stock .84 housing, with a wastage,...what rpm are you spooling at? Mine is coming alive at about 1600 rpm and really takes off at 1800... Just curious since you have the same sticks as mine and probably same gearhead tuning. With my wastage set at 34psi my egts never get over 1200
post #9 of 9 (permalink) Old 09-26-2013, 05:02 PM
I'd say starts at 1800, comes alive about 2000-2100. With an auto its not bad to drive at all. Matt's all out tune is a little smokey till it lites.
She's good enough to make a guy on a custom 1400 sportster wonder what the hell was going on when he tried to pass me lol.
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
