Did the ICP resistor mod the other day - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-07-2012, 05:13 AM Thread Starter
turboranger91's Avatar
Went with a 3.9k resistor. Holy crap! Can you say throttle response?! The idle is a bit too lopey for my taste, but the performance gains are way more than I anticipated them being. Can't wait to get a chip now, if this is any indication of how it will perform.
2001 xlt extended cab long bed 2wd auto
DIY 6637
Straight piped
hypertech max energy programmer
turboranger91 is offline
post #2 of 7 (permalink) Old 12-07-2012, 06:35 AM
Re: Did the ICP resistor mod the other day
That is just a little taste of what a chip will do!
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #3 of 7 (permalink) Old 12-07-2012, 03:40 PM
Old Yeller, REBORN
kilapapipa's Avatar
, then injectors and turbo upgrade
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #4 of 7 (permalink) Old 12-07-2012, 10:29 PM
OBS Stroker
Nodge's Avatar
If you do end up getting a chip, it would be wise to remove the resistor.
Until then, enjoy!
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #5 of 7 (permalink) Old 12-08-2012, 03:45 AM Thread Starter
Until then, enjoy!
absolutely. i'm trying to work out a deal right now with a chip. if this one falls through, i'll try another. either way, i'll have one within the next couple of weeks. i'll definitely be pulling the resistor out when the chip goes in.
the only thing i don't like is that when i romp on it for more than just a few seconds, it throws a code. granted, the ses light goes out within a few minutes, but i just don't like seeing it on at all. lol.
DIY 6637
Straight piped
post #6 of 7 (permalink) Old 12-10-2012, 01:50 AM
Terminator Nation
Its lopey because you are supposed to use a 5.6K resistor.
old man dave is offline
post #7 of 7 (permalink) Old 12-10-2012, 07:27 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
The code is because of the ICP pressures. The PCM knows something is wrong, just cant figure out what it is.
FYI... Your picking up maybe 20hp with any ICP mod.
Joe
CSIPSD is offline
