REG Return - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 09-12-2007, 03:07 PM Thread Starter
Just A Squirrel
dstruble's Avatar
REG Return
Waitin on my ITP reg return kit Anyway do i need to change out my#8 injector?? How do i tell if its a LL?? thanks for any input!!
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
dstruble is offline
post #2 of 22 (permalink) Old 09-12-2007, 04:41 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: REG Return
It will be a LL... I dont think you have to change it, but if you want to you can...
It will say on the top if the injector, AD and then in smaller letters LL
Joe
CSIPSD is offline
post #3 of 22 (permalink) Old 09-12-2007, 04:44 PM
< pissed off pumkin.
skylinedan's Avatar
Re: REG Return
I did a reg. return kit set up and never changed the injector, no problems that I can see or hear with mine .
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #4 of 22 (permalink) Old 09-12-2007, 04:45 PM
Member
vapstroke's Avatar
Re: REG Return
Dennis told me as long as it runs ok to leave the long lead in.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #5 of 22 (permalink) Old 09-12-2007, 09:09 PM
Bill
badford350's Avatar
Re: REG Return
same hear I just installed mine about a month ago. no problems at all. give dennis a call if your still in doubt he explained it pretty well to me.
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
post #6 of 22 (permalink) Old 09-14-2007, 06:04 AM
Lost refugee from TDS
Re: REG Return
My memory is fading quite a bit, but it was my understanding that by late 2002 (for early 2003 model years), the LL was no longer installed at the engine plant. If that was true, then your '03 wouldn't have an LL anyway.
But please don't take this as gospel, it was just a detail I had a faint recollection of from 5 years ago that needs to be verified first.
Robyn is offline
post #7 of 22 (permalink) Old 09-14-2007, 07:02 AM
Re: REG Return
I think you have that bass ackwards. The 02-03 trucks were the ones to get it, earlier ones did not have the LL injector.
gregrob is offline
post #8 of 22 (permalink) Old 09-14-2007, 10:16 AM
Haul_n_horses2's Avatar
Re: REG Return
Ditto on what Gregrob said. In the earlier years, a LL (AE) injector was installed in response to customer complaints about cackle. In '02 and later they all came that way.
Haul_n_horses2 is offline
post #9 of 22 (permalink) Old 09-14-2007, 12:35 PM
Re: REG Return
You are probably better off without the LL injector. It is my understanding the reg fuel system and hpx crossover will correct the dead head problem which effects your #8 injector. It shouold quiet down.
NWSUPRD is offline
post #10 of 22 (permalink) Old 09-14-2007, 12:39 PM
Re: REG Return
The HPX has nothing to do with the need for an AE or LL injector. Why wouldn't you want 8 identical injectors? The regulated return eliminates the dead end fuel rails and allows air to escape without passing through the injectors. Do you know of any other diesel or gas engines where all of the injectors are the same except one?
