ccv mod concerns - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 76 (permalink) Old 12-03-2012, 07:01 PM Thread Starter
ccv mod concerns
So i am about to do my ccv mod...everything i have read says to make sure it flows downhill. I have a 99 f350 and the rear end sits noticeably higher in the back. I would like to run the hose all the way to the rear of the truck. However in doing so, it will be running uphill the length of the frame. Any recommendations?
Also when spinning the doghouse is there a gasket i need to buy that seals the doghouse to the cover?
kenmore is offline
post #2 of 76 (permalink) Old 12-03-2012, 07:19 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: ccv mod concerns
Use the same gasket, route the hose over the master cylinder and down. Not sure how to get it to the back of your truck. Mine ends just behind the cab along the frame rail.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #3 of 76 (permalink) Old 12-03-2012, 08:01 PM
the stryker god
If you route it over the booster the oil will run back in the valve cover. Mine just spits on the ground.
bruce51d is offline
post #4 of 76 (permalink) Old 12-03-2012, 09:11 PM Thread Starter
Yea i read to make sure it goes over the brake reservoir, but running uphill after that isnt as big a deal then?
kenmore is offline
post #5 of 76 (permalink) Old 12-04-2012, 01:30 PM
'05 Excursion
Term3's Avatar
Any low spots have the possibility of collecting moisture and oil which can freeze in cold weather which will blow oil seals.
Sent from Term3's iPhone
Term3 is offline
post #6 of 76 (permalink) Old 12-04-2012, 02:16 PM Thread Starter
That is my main concern. Any recommendations? I plan on doing a leveling kit but i wasnt planning on doing it so soon.
kenmore is offline
post #7 of 76 (permalink) Old 12-04-2012, 02:20 PM
Old Yeller, REBORN
kilapapipa's Avatar
Don't run it to the back of your truck for now. Just dump it below the cab. Mine empty's just after the fuel pump and I have no issues in the cab as far as smell or anything.
post #8 of 76 (permalink) Old 12-04-2012, 02:25 PM Thread Starter
I may just do that. I could always put a filter/catch can there too and call it good.
kenmore is offline
post #9 of 76 (permalink) Old 12-05-2012, 09:43 AM
econolaw
olyaee's Avatar
I've ran it on a few peoples trucks to the end of the cab without any ups but, the smell was too much for a couple of them, so I ended up rerouting to the spare tire - no problems to report yet. I actually reinstalled the ccv on my van when the new motor went in. The builder insisted on negative crank-case pressure, so a bung was welded into the intake, then a custom 3/4"i.d. hose was made to connect it to the dog house.
2001 E-350 15 pass
olyaee is offline
post #10 of 76 (permalink) Old 12-05-2012, 02:18 PM
theoldgirl1990's Avatar
Mine may be a bit more annoying, but I opted not to flip the dog house, and just ran the hose straight down by the wheel well and hooked it onto the front axle by the pumpkin. There, I know I will not have any low spots. A bit more blow by smell at idle, but it works.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
